MSE Location Analytics stopped collecting data
jpop00001
I'm using MSE 7.4 and using Location analytics.  I got 5 days of data, and now its no longer collecting data.
When i go to the location analytics GUI the only day i can select is almost 2 weeks ago.  When I run reports directly from the MSE, those work fine.
Any idea on where I can start looking?
20 Replies 20
tosormun
What are the contents of the /opt/mse/logs/analytics/mse.log.o file? What is displayed when typing df -k (checking the disk space for MSE?
Ah finally posting!  Here's my error log.
10/15/13 18:39:28.277 ERROR[location] [18] AesNmspServiceMessageHandler.processImpl(target,request,seqNum,locpMessage) 10.159.0.50 ServiceSubscribeRequest 0 ServiceSubscribeResponse
10/15/13 18:39:28.277 ERROR[location] [18] AesNmspServiceMessageHandler.processImpl Received failure for subscription request
10/15/13 18:39:32.624 ERROR[core-engine] [25] Error in getting licensing limits. Attempt: 1 com.aes.server.mse.MSEClientException: getLicensingCapabilities: Licensing is not available, please try again later
10/16/13 08:22:00.413 ERROR[config] [52] AesLogJULImpl- syslog method : Exception while trying to log to external SyslogServer.
10/16/13 08:22:00.413 ERROR[config] [52] java.io.IOException: Message too long
At the end of the /opt/mse/logs/analytics/mse.log file (whichever is the newest and actually I believe that the path to this file in 7.4 may be /opt/mse/analytics/intellify/tools/MSEclient) it should look something like what is listed below. If there is something else, then the analytics process has stopped, you may wish to manually stop/start the mse process     /etc/init.d/msed restart     and/or   reboot, the mse and analytics processes will restart as the box comes back up. Remember the MSE process and the Analytics process are seperate, the MSE process works by itself with no dependency on the Analytics process however if the MSE process is down the Analytics process cannot work.
Also what does    getserverinfo display, I see some mention of exceeding license limits (the results of getserverinfo with tell us what those are. Also is it possible to upgrade to 1.4 Prime/7.5 MSE, the images and instructuctions can be found at cisco.com web site.
PROCESS MANAGER STARTING READDATA
          --------------- ATOM STARTING ZoneReaderProcess :  starting
          --------------- ATOM COMPLETED IN 0 ms ZoneReaderProcess :  4 zones read.
PROCESS MANAGER COMPLETED READDATA
Starting write
PROCESS MANAGER STARTING STORE_DATA_2/2
          --------------- ATOM STARTING PathWriterProcess :  starting
          --------------- ATOM COMPLETED IN 20 ms PathWriterProcess :  Saved 2 paths (rejected 0 duplicates).
PROCESS MANAGER COMPLETED STORE_DATA_2/2
Stored 2 paths for 2 devices. Total of 2 points (avg: 1.00 points/path)
Clearing device cache
Previous point count: 224679, points added since last stats gathered: 42000
Finished
Pruning database...
Max points: 2000000
Reset points: 1900000
Pruned 0 points
Finished at 2013-10-17T08:42:50.321-05:00 ============================================================
I have to be honest I'm not the Main Cisco guy so I'm not quite sure I know exactly how to get some of these, I've just been tasked with trying to get Analytics working.  I have access to the cisco prime infrastructure and the logs I get are from there.
The license issue is because we're under licensed for the number of elements that are being collected.  We peak at around 3000 elements but are only licensed for 500 currently.  We're trying to prove out the accuracy and the validity of the data before we purchase more..
I'm not sure how to run the console commands, can i do that from the MSE?  The logs are what I get when I use the download logs button under Services > Mobility Services Engines > cmse > system > logs
To grab the logs I refer to you will need to have cli access to the MSE. This is typically accomplished by using an ssh session   ssh -l root ipaddress   or if the MSE is an appliance you may connect via the console port on the box. Once at the cli for the mse   type    getserverinfo,     this will display a bunch of stuff that is useful in understanding what the state of the mse is.  Also the retrieve the contents of the files I mention, from the cli on the MSE navigate to the directory and either using vi to grab the file contents or type cat filename   (like this   cat mse.log.0), this will display the entire contents of the log file which can be copied and pasted into some text edit progam. Remeber for this file we only care about what is at the bottom couple lines.
I would recommend moving to the latest code release (7.5 MSE/1.4 Prime) as there are many improvements over 7.4. Information, release notes, additional troubleshooting information, etc. may be found here ---
http://www.cisco.com/en/US/products/ps9742/index.html       MSE
http://www.cisco.com/en/US/products/ps12239/index.html     Prime
why do my comments sometime require approval by moderator and sometimes not?
Here's the bottom of the mse.log file:
PROCESS MANAGER STARTING STORE_DATA_3/3
java.sql.SQLException: ORA-01654: unable to extend index ANALYTICS.PATH_PK by 8 in tablespace ANALYTICS
ORA-06512: at "ANALYTICS.PATH_PACKAGE", line 9
ORA-06512: at line 1
        at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:439)
        at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:395)
        at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:802)
        at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:436)
        at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:186)
        at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:521)
        at oracle.jdbc.driver.T4CCallableStatement.doOall8(T4CCallableStatement.java:202)
        at oracle.jdbc.driver.T4CCallableStatement.executeForRows(T4CCallableStatement.java:1005)
        at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1307)
        at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3449)
        at oracle.jdbc.driver.OraclePreparedStatement.execute(OraclePreparedStatement.java:3550)
        at oracle.jdbc.driver.OracleCallableStatement.execute(OracleCallableStatement.java:4710)
        at oracle.jdbc.driver.OraclePreparedStatementWrapper.execute(OraclePreparedStatementWrapper.java:1374)
        at ie.thinksmarttechnologies.intellify.locationintelligence.db.processes.PathWriterProcess.insertPaths(PathWriterProcess.java:511)
        at ie.thinksmarttechnologies.intellify.locationintelligence.db.processes.PathWriterProcess.executeLinkedAtom(PathWriterProcess.java:2091)
        at ie.thinksmarttechnologies.intellify.chaining.process.LinkedProcess.executeAtom(LinkedProcess.java:44)
        at ie.thinksmarttechnologies.intellify.chaining.process.AbstractProcessAtom.execute(AbstractProcessAtom.java:21)
        at ie.thinksmarttechnologies.intellify.chaining.process.ProcessManager.executeAtom(ProcessManager.java:116)
        at ie.thinksmarttechnologies.intellify.chaining.process.ProcessManager.execute(ProcessManager.java:105)
        at ie.thinksmarttechnologies.com.mseconnector.mseapi.Scraper.sendPathsToOracle(Scraper.java:650)
        at ie.thinksmarttechnologies.com.mseconnector.mseapi.Scraper.run(Scraper.java:258)
        at ie.thinksmarttechnologies.com.mseconnector.Main.run(Main.java:184)
        at ie.thinksmarttechnologies.com.mseconnector.Main.main(Main.java:484)
        PROCESS MANAGER FAIL STORE_DATA_3/3 : PathWriterProcess :  cause = ORA-01654: unable to extend index ANALYTICS.PATH_PK by 8 in tablespace ANALYTICS
Here is getserverinfo with the IPs replaced.  I've got to do this with multiple posts.  it wont let me add the whole thing at once
Health Monitor is running
Starting MSE Platform, Waiting to check the status.
MSE services are up, getting the status
Server Config
Product name: Cisco Mobility Service Engine
Version: 7.4.110.0
Health Monitor Ip Address: 1.1.1.1
High Availability Role: 1
Hw Version: V01
Hw Product Identifier: AIR-MSE-VA-K9
Hw Serial Number: xxxxxx_62909fa0-1f05-11e3-80c0-005056837292
Use HTTP: false
Legacy HTTPS: false
Legacy Port: 8001
Log Modules: 24516
Log Level: INFO
Days to keep events: 2
Session timeout in mins: 30
DB backup in days: 2
Services
Service Name: Context Aware Service
Service Version: 7.4.0.45
Admin Status: Enabled
Operation Status: Up
Service Name: WIPS
Service Version: 1.0.4041.0
Admin Status: Disabled
Operation Status: Down
Service Name: Mobile Concierge Service
Service Version: 2.0.0.37
Service Name: Location Analytics Service
Service Version: 1.0.0.12
Server Monitor
Server start time: Tue Oct 15 18:39:25 EDT 2013
Server current time: Thu Oct 17 11:33:33 EDT 2013
Server timezone: US/Michigan
Server timezone offset: -18000000
Restarts: 6
Used Memory (bytes): 181712032
Allocated Memory (bytes): 532873216
Max Memory (bytes): 954466304
DB virtual memory (kbytes): 0
DB virtual memory limit (bytes): 0
DB disk memory (bytes): 33657628288
DB free size (kbytes): 0
Could this be the issue under Server monitor?  DB free size (kbytes): 0
Server Monitor
Restarts: 6
DB free size= 0  <---***is this the problem?  No free DB space?***
Server Monitor
Server timezone: US
Restarts: 6
Used Memory: 181712032
Allocated Memory : 532873216
Max Memory : 954466304
DB virtual memory : 0
DB virtual memory limit: 0
DB disk memory : 33657628288
DB free size: 0  <---***is this the problem?  No free DB space?***
Server Monitor
Restarts: 6
DB free size (kbytes): 0  <---***is this the problem?  No free DB space?***
