09-01-2018 08:29 AM - edited 07-05-2021 09:04 AM
We have a WLC 5520 with 3802E/I APs in flexconnect (local switching).
The Global Multicast is not enabled.
In the General tab the multicast is on multicast/multicast mode with 239.x.x.x group
Is this multicast mode is enabled even if the global multicast mode is not enabled ?
Because as we are running with flexconnect mode, we need to do multicast-unicast I assume.
09-02-2018 03:59 AM
You don't need multi cast because you are running AP in flexconnect. You need multicast if you are running some application that requires multicast.
The wireless controller may use multicast to deliver information to the APs but it is part of the management process and you don't need to worry about.
-If I helped you somehow, please, rate it as useful.-
09-02-2018 09:41 AM
Ok thanks for your answer. But precisely, is multicast-multicast is still enabled, even if global multicast mode is disableld ?
09-02-2018 01:46 PM
No. Refer below thread as it got useful information about multicast with FlexConnect.
Rasika
*** Pls rate all useful responses ****
