Highlighted
Beginner
multiple MSEs
Due to high number of APs, I need to deploy a separate MSE   to provide  location services and  aWIPS. :-(
In this scanrio,  is it possible to share the  same floor map  which contain local and WSSI APs  between the 2 MSEs?
the tracking elements  per mse are given below.
awips: rogue clients, rogue aps, adhoc rogues, interferes
location services: wlan clients,rogue aps,interfers,rfid tags
Thanks in advance.
cheers,
janesh
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
Well from WCS/NCS/PI, you can only assign one MSE to a given floor.
-Scott
4 REPLIES 4
Highlighted
Hall of Fame Master
-Scott
Highlighted
Thanks Scott for the clarification.
Highlighted
No problem
-Scott
Highlighted
Hello Janesh,
As per your query you want to deploy a separate MSE to provide location services and a WIPS.
No. it is not possible to share the same floor map which contain local and WSSI APs between the 2 MSEs.
Content for Community-Ad
