10-26-2017 07:50 AM - edited 07-05-2021 07:46 AM
Hello all,
I've had a second deployment failure with Cisco AIR-AP-1832i WLC/APs running Mobility Express. The issue is that I can't seem to get off VLAN1, or I suppose it would be more accurate to say the native VLAN.
Scenario is that I have two WLANs as follows:
WLAN1: SSID: Corporate VLAN: 1
WLAN2: SSID: Corporate-Guest VLAN: 100
I can connect to either WLAN/SSID successfully with a client. But only the Corporate WLAN gets me to the proper DHCP server and gives me the ability to pass traffic successfully. Connecting to Guest fails to locate a DHCP server, so I get an APIPA address and nothing works. Configuring a static IP on the proper subnet does not allow traffic to pass.
In this deployment, I am using a Cisco Catalyst 2960 switch with the WLC/AP port being a trunk with dot1q. Here's the best part: I replaced a Cisco WAP321 (yeah, small business) AP with the same WLAN/VLAN/SSID configuration that was connected to the very same switch port. The WAP321 handled the two SSIDs and VLANs perfectly. No issues whatsoever connecting, getting IP addresses on either network or passing traffic. I made no changes to the switch configuration.
The previous failed deployment I had was a bit different in symptoms: The VLAN configuration was the same, a corporate network and guest network, corporate was on VLAN1 and Guest was VLAN 10. This time, I could connect to either SSID, but I would always get an IP address from the DHCP server on VLAN 1. It's like the VLAN 10 tag was completely ignored. I had a TAC case on that one that became a nightmare when Cisco could find nothing wrong with my configuration of the WLC/AP, switch, or ASA (DHCP server for VLAN 10). They could offer no explanation, even though I provided a pcap from the WLC's switchport (mirrored to my laptop running Wireshark) to TAC. I opted to RMA the 1832s in that case after TAC failed to resolve the situation. I haven't deployed the new APs (different vendor) yet.
Anyway, my question to anyone familiar with these 1832i series units is, what am I missing, or is there a known problem with these things? I don't have these issues with real Cisco WLCs (2504 for example) or even the small business line, although Cisco's new crop is terrible and I won't buy them.
By the way, these last 1832i's shipped with 8.4.100.
06-16-2019 06:33 AM
I had this same issue, and searched high and low... debug on the 2811 router doing my static DHCP reservations for the additional WLANs showed nothing, I was converting from NM-WLC to ME, so thought some of that config such as the 'interface wlan-controller0/0.x'was it, carefully developed a cut and paste to change over and back out the changes, and it made no difference... I used the 'connection' and 'event log' at the bottom of the ME client window to see that the DHCP requests seemed to be going out... I upgraded from the recommended 8.5 to 8.8, and no change... I sat there for another hour just thinking about how to test, thinking it had to be in the switch, but things like helper addresses were not required, and then BAM... I realized the VLAN was not defined in the switch that was powering the 1832... One simple command in the switch and it started working... even after 20 years, the simple stuff still gets you once in a while..
It may not be your issue, but the symptoms are the exact same...
09-19-2019 05:34 PM
I tried all the suggestions in this thread and none worked for me until I looked into the flexconnect configuration.
I checked the flexconnect configuration by running this command "show ap config general AP1234.5678...." and it was disabled.
(Cisco Controller) >show ap config general AP1234.5678....
FlexConnect Vlan mode :.......................... Disabled
To enable Flexconnect on the AP I ran the following commands:
config ap disable AP1234.5678....
config ap flexconnect vlan enable AP1234.5678....
config ap enable AP1234.5678....
After enabling Flexconnect on the AP successfully and configure the Vlan on the WLAN, I get the following:
FlexConnect Vlan mode :.......................... Enabled
Native ID :..................................... 1
WLAN 1 :........................................ 55 (Wlan-Specific)
WLAN 2 :........................................ 54 (Group-Specific)
Success at last. I hope this helps someone because it was very frustrating for me especially when the Cisco Mobility Express GUI has very limited configuration options.
12-04-2019 10:13 PM
02-10-2021 10:17 AM
Hello all,
My remedy to this is the following:
Remove any DHCP pools from box itself and rely on an external DHCP for all VLANs including native.
That made all the stuff work
Chris
08-24-2021 07:45 AM
is there an solution yet? I run the Version 8-10-162-0.
My Problem:
MGMT VLAN 233
WLAN 1 VLAN 61
WLAN 2 VLAN 62
My Switchconfig:
switchport trunk native vlan 233
switchport trunk allowed vlan 61,62
switchport mode trunk
I create WLAN 1 with VLAN 61 an get an DHCP address from VLAN 233. The DHCP-Server is external and not on the AP.
Thanks for Help.
03-04-2024 12:22 AM
Configure switchports in trunk where APs are connected.
03-05-2024 02:37 AM
No, probably the correct answer to the previous post (if that's what you were referring to) was missing allowed VLAN:
switchport trunk allowed vlan 61,62 <- missing vlan 233!
