NCS localdiskvol about recommended disk usage
JASON SIMMONS
Level 2
Level 2
I received this error today.
NCS disk volume 'localdiskvol' is above the recommended disk usage, more than '70'% used.
What do I need to do to reduce the disk usage?
M. Wisely
Level 4
Level 4
We had this issue as well and in our case it was because we enabled backups and the default destination is that volume. We changed where the backup go to another repository and deleted the backups in disk:/defaultRepo to clear the issue.
johncaston_2
Might need to log a TAC case for that one
I know there's 3 different VM images, depending on the size of the wireless deployment, each image with more memory and disk
One would assume that the VM disk allocation and underlying Linux partition could be expanded, worst case is you could install a bigger image build and export the data and licenses across - hopefully you shouldn't have to go to that
Be interested to know what the resolution is
M. Wisely
Level 4
Level 4
