5814
Highlighted
Beginner
Need helping adding new access point to WLC 5508
We got some new AP's for a IDF we just installed. I changed the VLAN's  on the ports for the AP's and my DHCP server shows the AP's but how do I add them into the WLC to be available to my users? We have a WLC and NCS. I think I can add it to either but I just cannot figure it out. I dont see the new AP's listed on the WLC anywhere.
4 REPLIES 4
Beginner
I will add that when this was
I will add that when this was originally setup we never got option 43 to work on the DHCP server so the vendor must have used a work around even though the DHCP server on our AD server does provide the ip.
Hi,1.) We have a WLC and NCS.
1.) We have a WLC and NCS. I think I can add it to either but I just cannot figure it out.
>> We can only add the APs to WLC. NCS is to monitor/manage WLCs and APs.
2.) how do I add them into the WLC to be available to my users?
>> See if the doc at this link helps you to get the APs registered to the WLC : http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/99948-lap-notjoin-wlc-tshoot.html
Thanks & Regards,
Ishant
*** Please rate the post if you find it useful ***
Beginner
I cannot tell if the WLC is
I cannot tell if the WLC is doing the discovery or not. This guide is not helping me much. I never have had to deal with this WLC before so I should have mentioned that. This is my first attempt at the wireless setup here.
Rising star
Please refer  to the link for
Please refer  to the link for Access Point registeration to the WLC step by step configuration guide-
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/70333-lap-registration.html
Content for Community-Ad
August's Community Spotlight Awards
