206
Highlighted
Beginner
Need to upgrade 5508 from 7.6.130 to 8.3.xx.
Dear Members,
I need to upgrade 5508 from 7.6 to 8.3.xx. Do i need to upgrade FUS image latest to 1.9. Attached is the screenshot regarding the current SH SYSINFO command output.
7 REPLIES 7
VIP Mentor
Re: Need to upgrade 5508 from 7.6.130 to 8.3.xx.
Hi Kashif,
Cisco recommand to upgrade the FUS version to 1.9 specially if you want to run the 8.3 code on WLC.
https://software.cisco.com/download/home/282600534/type/284364857/release/1.9.0.0
Regarding Software upgrade: First you need to move from 7.6 to 8.0 version then to 8.3.150.0(Direct upgrade from 7.6 to 8.3.150.0 is not possible)
https://software.cisco.com/download/home/282600534/type/280926587/release/8.3.150.0
Dont forget to rate helpful posts
Beginner
Dear Brother,
Very pleased to get help from you. Have you seen the attachement contaning
SHOW SYSINFO? Can you tell me the current FUS image version against current
SHOW SYSINFO output.
Rising star
 - Too blurred, please provide good quality.
    M,
Beginner
Dear Marce100,
Here is the SHOW SYSINFO Output.
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.130.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.7, Env 1.8,
USB console
2.2
Build Type....................................... DATA + WPS
VIP Mentor
currently you are running:
Bootloder version: 1.0.1
FIRV: 6.0.102.0
FYI: FUS contain many other parameters..
onc you upgrade to FUS version 1.9 you will see....like this
* Field Recovery Image is upgraded from 6.0.102.0 to 7.6.101.1
* Bootloader is upgraded to 1.0.20
* Offline Field Diagnostics is upgraded from 0.9.28 to 0.9.35
Beginner
Dear Sandeep,
Thank you so much for your help. So it means i need upgrade the FUS image
first then upgrade the IOS.
VIP Mentor
yes upgrdae FUS and then software. But make sure you take a downtime of 1 hour as FUS image alone will need 45 min.
Dont forget tot rate helpful posts
Content for Community-Ad
August's Community Spotlight Awards
