Need to upgrade 5508 from 7.6.130 to 8.3.xx.
kashifglobal12
Dear Members,
I need to upgrade 5508 from 7.6 to 8.3.xx. Do i need to upgrade FUS image latest to 1.9. Attached is the screenshot regarding the current SH SYSINFO command output.
7 Replies 7
Sandeep Choudhary
Hi Kashif,
Cisco recommand to upgrade the FUS version to 1.9 specially if you want to run the 8.3 code on WLC.
https://software.cisco.com/download/home/282600534/type/284364857/release/1.9.0.0
Regarding Software upgrade: First you need to move from 7.6 to 8.0 version then to 8.3.150.0(Direct upgrade from 7.6 to 8.3.150.0 is not possible)
https://software.cisco.com/download/home/282600534/type/280926587/release/8.3.150.0
Dont forget to rate helpful posts
Dear Brother,
Very pleased to get help from you. Have you seen the attachement contaning
SHOW SYSINFO? Can you tell me the current FUS image version against current
SHOW SYSINFO output.
 - Too blurred, please provide good quality.
    M,
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
Dear Marce100,
Here is the SHOW SYSINFO Output.
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.130.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.7, Env 1.8,
USB console
2.2
Build Type....................................... DATA + WPS
currently you are running:
Bootloder version: 1.0.1
FIRV: 6.0.102.0
FYI: FUS contain many other parameters..
onc you upgrade to FUS version 1.9 you will see....like this
* Field Recovery Image is upgraded from 6.0.102.0 to 7.6.101.1
* Bootloader is upgraded to 1.0.20
* Offline Field Diagnostics is upgraded from 0.9.28 to 0.9.35
Dear Sandeep,
Thank you so much for your help. So it means i need upgrade the FUS image
first then upgrade the IOS.
yes upgrdae FUS and then software. But make sure you take a downtime of 1 hour as FUS image alone will need 45 min.
Dont forget tot rate helpful posts
