02-11-2020 12:38 AM - edited 07-05-2021 11:40 AM
I have inherited a 2504 WLC (still running7.0.220.0) which has one corporate SSID defined.
I intend to create a new SSID and interface for a guest network, which will be on a separate subnet and VLAN. The VLAN is yet to be defined.
I am running into trouble when creating the interface. The first screenshot is of the current interface named 'management', the second screenshot is what I am trying to create, and the third is the error message that I am consistently receiving, no matter what tweaks I make to the settings for the new interface.
Existing Interface:
New Interface Details:
Error Message:
Solved! Go to Solution.
02-11-2020 12:56 AM
also assign the VLAN dientifier (example: 60)
Dont forget to arte helpful posts
02-11-2020 12:46 AM
check the gateway IP address as you are iusing /24 mask. If you IP address is 10.234.60.9 then gateway msut be in same subnet (example: 10.234.60.1)
Dont forget to rate helpful posts
02-11-2020 12:49 AM
Thanks Sandeep. I've just adjusted it to the settings below and get hit with the same error message again. 'Could not set the port configuration.'
02-11-2020 12:56 AM
02-11-2020 01:14 AM
Thanks again. That seems to have made progress as it is now prompting to restart the WLC. Would need to do that outside of core hours, so pop in early one day this week, and will let you know how it goes. Thanks
02-11-2020 01:15 AM
Great. Let me know the status.
02-11-2020 01:22 AM - edited 02-11-2020 01:30 AM
can you paste the screenshot of the managemnt interface configuration ?
or output of the command: show interface detailed management
02-11-2020 01:26 AM
Is that what you needed?
02-11-2020 01:32 AM
Assign Port Number to :1
Backup Port 2: 0
If you are creating new dynamic interface then dont chekc the box for : Enable Dynamic AP Management
Change these and try again.
02-11-2020 01:58 AM
Yes that is management interface output.
Paste the output of the interface which you are trying create ? Also include the error screenshot.
02-12-2020 12:21 AM
Hi Sandeep,
This is the configuration that I am attempting, and the messages that I received.
02-12-2020 12:21 AM
Just to follow on from this. I have successfully created the interface, but had to use port 2.
Would you expect this to be the case?
Is it as simple now as just going and connecting port 2 to a switch?
02-12-2020 08:14 AM
02-12-2020 12:39 AM
These messgae is ok. It will not create any issue except the clinet to reconnect to WLAN.
