Community Helping Community
460
Enthusiast
Nexus and a 5508
Anyone setup a 5508 and a Nexus 5548P yet?  Anything I should know about, or do I just make the usual port channels?
Scott
4 REPLIES 4
Re: Nexus and a 5508
Hi Scott,
nothing special normally. Just make the etherchannel load balancing as "src-dst-ip" and you should be good to go.
Also remember to not put any portchannel negociation, just mode "on".
Nicolas
Don't forget to rate answers that you find useful
Enthusiast
Hey Scott,
Also make sure you use "spanning-tree port type network" on the Nexus side.
Enthusiast
Thanks Kyle.  Is there any guide for connecting to a Nexus, or do I just have to pay attention to the protocols/technologies in use?
Scott
Highlighted
Enthusiast
There's no guide that I know of just pay attention to the same basics as you would for an etherchannel to a 6500 for example with the addtion on the above spanning-tree command and be sure to use "mode on" for the port channel. HTH. Good luck!
Content for Community-Ad
August's Community Spotlight Awards
