03-12-2019 01:52 AM - edited 07-05-2021 10:02 AM
I am installing the new Cisco AIR-AP2802I, I have converted it to cisco mobility express to be a controller. I need to setup the tacacs here, but I am not able to switch it to Expert view. This option is not there. Kindly see attached. What should I do? The IOS version is AIR-AP2800-K9-ME-8-3-143-0. Do I need upgrade it, or load some license?
I am total beginner with wifi APs, I am very happy I was able to convert it to mobility express and make it connected.
Please help me.
Solved! Go to Solution.
03-12-2019 02:01 AM
03-12-2019 02:01 AM
03-12-2019 02:15 AM
thank You for good answer, I will check it and will let you know
