Not able to achieve 802.11n bandwidth
newtamil2011
Hi Experts,
We are having 2504 WLC with 1042APs(2 spatial streams , 300Mbps) .Our clients are getting connection speed of maximum 72Mbps only in 2.4GHZ as well as 5GHZ
I have tried the below settings , but still the speed only
1.Radio policy all
2.WMM enabled
3.WPA2 AES settings only
4.Channel width 40MHZ in 5GHZ band.
For example My laptop always connecting in the 2.4GHZ band and I am getting maximum of 72 Mbps only in office. If i use it in my home , i m getting connection speed of 150Mbps. My home wifi router has 1 spatial streams.
5 Replies 5
Pls post "show client detail <client_mac_address>" output when this is happening.
Also what happens if you disable 2.4GHz radio on your AP ? Does your laptop connecting in 5GHz ? If that works, better to enable "band select" on your SSID to prefer 5GHz over 2.4GHz
Rasika
I have tried the option of enabling band select feature , but soon some of the clients are unable to connect only. Hence i disbled the option again.
Pls fnd the output below, it consists of bgn , g , an client
(Cisco Controller) >show client detail 04:46:65:2f:b9:c1
Client MAC Address............................... 04:46:65:2f:b9:c1
Client Username .................................
AP MAC Address................................... 1c:e6:c7:4a:2a:20
AP Name.......................................... 1
Client State..................................... Associated
Client NAC OOB State............................. Access
Wireless LAN Id.................................. 6
Hotspot (802.11u)................................ Not Supported
BSSID............................................ 1c:e6:c7:4a:2a:25
Connected For ................................... 100 secs
Channel.......................................... 11
IP Address.......................................
Gateway Address..................................
Netmask.......................................... 255.255.254.0
Association Id................................... 116
Authentication Algorithm......................... Open System
Reason Code...................................... 1
Status Code...................................... 0
Client CCX version............................... No CCX support
Re-Authentication Timeout........................ 1678
QoS Level........................................ Silver
802.1P Priority Tag.............................. disabled
--More-- or (q)uit
CTS Security Group Tag........................... Not Applicable
KTS CAC Capability............................... No
WMM Support...................................... Enabled
  APSD ACs.......................................  BK  BE  VI  VO
Power Save....................................... OFF
Current Rate..................................... 5.5
Supported Rates.................................. 1.0,2.0,5.5,11.0,6.0,9.0,
    ............................................. 12.0,18.0,24.0,36.0,48.0,
    ............................................. 54.0
Mobility State................................... Local
Mobility Move Count.............................. 0
Security Policy Completed........................ Yes
Policy Manager State............................. RUN
Policy Manager Rule Created...................... Yes
Audit Session ID................................. 0a12280500142896564f132d
IPv4 ACL Name.................................... none
IPv4 ACL Applied Status.......................... Unavailable
IPv6 ACL Name.................................... none
IPv6 ACL Applied Status.......................... Unavailable
mDNS Status...................................... Disabled
mDNS Profile Name................................ none
No. of mDNS Services Advertised.................. 0
Policy Type...................................... WPA2
--More-- or (q)uit
Authentication Key Management.................... 802.1x
Encryption Cipher................................ CCMP (AES)
Protected Management Frame ...................... No
Management Frame Protection...................... No
EAP Type......................................... PEAP
Interface........................................ h
VLAN............................................. 255
Quarantine VLAN.................................. 0
Access VLAN...................................... 255
Client Capabilities:
      CF Pollable................................ Not implemented
      CF Poll Request............................ Not implemented
      Short Preamble............................. Implemented
      PBCC....................................... Not implemented
      Channel Agility............................ Not implemented
      Listen Interval............................ 1
      Fast BSS Transition........................ Not implemented
Client Wifi Direct Capabilities:
      WFD capable................................ No
      Manged WFD capable......................... No
      Cross Connection Capable................... No
      Support Concurrent Operation............... No
Fast BSS Transition Details:
--More-- or (q)uit
Client Statistics:
      Number of Bytes Received................... 7946
      Number of Bytes Sent....................... 16179
      Number of Packets Received................. 59
      Number of Packets Sent..................... 60
      Number of Interim-Update Sent.............. 0
      Number of EAP Id Request Msg Timeouts...... 0
      Number of EAP Id Request Msg Failures...... 0
      Number of EAP Request Msg Timeouts......... 0
      Number of EAP Request Msg Failures......... 0
      Number of EAP Key Msg Timeouts............. 0
      Number of EAP Key Msg Failures............. 0
      Number of Data Retries..................... 31
      Number of RTS Retries...................... 0
      Number of Duplicate Received Packets....... 0
      Number of Decrypt Failed Packets........... 0
      Number of Mic Failured Packets............. 0
      Number of Mic Missing Packets.............. 0
      Number of RA Packets Dropped............... 0
      Number of Policy Errors.................... 0
      Radio Signal Strength Indicator............ -67 dBm
      Signal to Noise Ratio...................... 27 dB
Client Rate Limiting Statistics:
--More-- or (q)uit
      Number of Data Packets Recieved............ 0
      Number of Data Rx Packets Dropped.......... 0
      Number of Data Bytes Recieved.............. 0
      Number of Data Rx Bytes Dropped............ 0
      Number of Realtime Packets Recieved........ 0
      Number of Realtime Rx Packets Dropped...... 0
      Number of Realtime Bytes Recieved.......... 0
      Number of Realtime Rx Bytes Dropped........ 0
      Number of Data Packets Sent................ 0
      Number of Data Tx Packets Dropped.......... 0
      Number of Data Bytes Sent.................. 0
      Number of Data Tx Bytes Dropped............ 0
      Number of Realtime Packets Sent............ 0
      Number of Realtime Tx Packets Dropped...... 0
      Number of Realtime Bytes Sent.............. 0
      Number of Realtime Tx Bytes Dropped........ 0
Nearby AP Statistics:
      4(slot 0)
        antenna0: 100 secs ago................... -54 dBm
        antenna1: 100 secs ago................... -53 dBm
      2(slot 0)
        antenna0: 100 secs ago................... -63 dBm
        antenna1: 100 secs ago................... -62 dBm
--More-- or (q)uit
      3(slot 0)
        antenna0: 100 secs ago................... -62 dBm
      2(slot 0)
        antenna0: 100 secs ago................... -70 dBm
        antenna1: 100 secs ago................... -83 dBm
      HMS2_2F_AP03(slot 0)
        antenna0: 100 secs ago................... -59 dBm
        antenna1: 100 secs ago................... -65 dBm
      HMS2_GF_AP01(slot 0)
        antenna0: 100 secs ago................... -64 dBm
        antenna1: 100 secs ago................... -70 dBm
      HMS2_2F_AP01(slot 0)
      HMS2_3F_AP04(slot 0)
        antenna0: 100 secs ago................... -73 dBm
      HMS2_GF_AP05(slot 0)
        antenna0: 100 secs ago................... -61 dBm
        antenna1: 100 secs ago................... -56 dBm
      HMS2_GF_AP02(slot 0)
        antenna0: 100 secs ago................... -69 dBm
--More-- or (q)uit
        antenna1: 100 secs ago................... -66 dBm
      HMS2_1F_AP03(slot 0)
        antenna0: 100 secs ago................... -67 dBm
        antenna1: 100 secs ago................... -69 dBm
      HMS2_1F_AP01(slot 0)
        antenna0: 100 secs ago................... -66 dBm
        antenna1: 100 secs ago................... -61 dBm
      HMS2_GF_AP04(slot 0)
        antenna1: 100 secs ago................... -73 dBm
      HMS2_GF_AP03(slot 0)
        antenna0: 100 secs ago................... -76 dBm
        antenna1: 100 secs ago................... -82 dBm
      HMS2_2F_AP02(slot 0)
      HMS2_3F_AP01(slot 0)
        antenna0: 100 secs ago................... -56 dBm
        antenna1: 100 secs ago................... -63 dBm
DNS Server details:
      DNS server IP .............................
Assisted Roaming Prediction List details:
--More-- or (q)uit
 Client Dhcp Required:     True
(Cisco Controller) >04:c2:3e:20:02:32                 show client detail 04:46:65:2f:b9:c1                 04:c2:3e:20:02:32
Client MAC Address............................... 04:c2:3e:20:02:32
AP MAC Address................................... 1c:e6:c7:85:2d:60
AP Name.......................................... H
Wireless LAN Id.................................. 1
BSSID............................................ 1c:e6:c7:85:2d:60
Connected For ................................... 1227 secs
Channel.......................................... 6
Association Id................................... 10
Re-Authentication Timeout........................ 547
--More-- or (q)uit
Power Save....................................... ON
Current Rate..................................... m5
Audit Session ID................................. 0a12280500142375564ef661
--More-- or (q)uit
FlexConnect Data Switching....................... Local
FlexConnect Dhcp Status.......................... Local
FlexConnect Vlan Based Central Switching......... No
FlexConnect Authentication....................... Central
Access VLAN...................................... 250
      Listen Interval............................ 2
--More-- or (q)uit
Client Statistics:
      Number of Bytes Received................... 3508976
      Number of Bytes Sent....................... 4660782
      Number of Packets Received................. 13470
      Number of Packets Sent..................... 9021
      Number of Data Retries..................... 6794
      Number of Duplicate Received Packets....... 8
      Radio Signal Strength Indicator............ -56 dBm
--More-- or (q)uit
      Signal to Noise Ratio...................... 35 dB
      HMS1_2F_NW_AP05(slot 0)
        antenna0: 50 secs ago.................... -76 dBm
        antenna1: 50 secs ago.................... -79 dBm
      HMS1_1F_NW_AP04(slot 0)
--More-- or (q)uit
        antenna0: 50 secs ago.................... -65 dBm
        antenna1: 50 secs ago.................... -66 dBm
      HMS1_2F_MR_AP07(slot 0)
        antenna0: 968 secs ago................... -84 dBm
        antenna1: 968 secs ago................... -90 dBm
      HMS1_GF_SW_AP03(slot 0)
        antenna0: 1604 secs ago.................. -87 dBm
        antenna1: 1604 secs ago.................. -90 dBm
      HMS1_2F_NW_AP06(slot 0)
        antenna0: 272 secs ago................... -74 dBm
        antenna1: 272 secs ago................... -74 dBm
      HMS1_3F_NW_AP02(slot 0)
        antenna0: 51 secs ago.................... -78 dBm
        antenna1: 51 secs ago.................... -82 dBm
      HMS1_GF_SW_AP02(slot 0)
        antenna0: 171 secs ago................... -84 dBm
        antenna1: 171 secs ago................... -89 dBm
      HMS1_2F_SW_AP03(slot 0)
        antenna0: 2630 secs ago.................. -84 dBm
        antenna1: 2630 secs ago.................. -90 dBm
      HMS1_1F_NW_AP05(slot 0)
        antenna0: 51 secs ago.................... -65 dBm
        antenna1: 51 secs ago.................... -65 dBm
--More-- or (q)uit
      HMS1_GF_NW_AP05(slot 0)
        antenna0: 50 secs ago.................... -59 dBm
        antenna1: 50 secs ago.................... -58 dBm
      HMS1_2F_SW_AP01(slot 0)
        antenna0: 1090 secs ago.................. -87 dBm
        antenna1: 1090 secs ago.................. -88 dBm
      HMS1_2F_NW_AP04(slot 0)
        antenna0: 50 secs ago.................... -86 dBm
        antenna1: 50 secs ago.................... -81 dBm
      HMS1_1F_SW_AP01(slot 0)
        antenna0: 5338 secs ago.................. -85 dBm
        antenna1: 5338 secs ago.................. -86 dBm
      HMS1_1F_NW_AP03(slot 0)
        antenna0: 2630 secs ago.................. -86 dBm
        antenna1: 2630 secs ago.................. -79 dBm
      HMS1_GF_SW_AP01(slot 0)
        antenna0: 1090 secs ago.................. -86 dBm
        antenna1: 1090 secs ago.................. -87 dBm
DNS Server details:
--More-- or (q)uit
(Cisco Controller) >show client detail 04:c2:3e:20:02:32                 4c:34:88:89:88:57
Client MAC Address............................... 4c:34:88:89:88:57
AP MAC Address................................... 1c:e6:c7:85:61:10
AP Name.......................................... HMS2_GF_AP05
BSSID............................................ 1c:e6:c7:85:61:1f
Connected For ................................... 1558 secs
Channel.......................................... 36
Client CCX version............................... 4
Client E2E version............................... 1
Re-Authentication Timeout........................ 270
--More-- or (q)uit
  APSD ACs.......................................  BK(T/D)  BE(T/D)  VI(T/D)  VO(T/D)
Current Rate..................................... m15
Supported Rates.................................. 6.0,9.0,12.0,18.0,24.0,36.0,
    ............................................. 48.0,54.0
Audit Session ID................................. 0a1228050014272c564f0a40
--More-- or (q)uit
Interface........................................ corp_wlan
VLAN............................................. 250
      Short Preamble............................. Not implemented
      Listen Interval............................ 225
--More-- or (q)uit
Client Statistics:
      Number of Bytes Received................... 7786631
      Number of Bytes Sent....................... 80271770
      Number of Packets Received................. 69686
      Number of Packets Sent..................... 87654
      Number of Data Retries..................... 13100
      Number of Duplicate Received Packets....... 21
      Radio Signal Strength Indicator............ -44 dBm
      Signal to Noise Ratio...................... 52 dB
--More-- or (q)uit
      HMS2_1F_AP04(slot 0)
        antenna0: 883 secs ago................... -66 dBm
        antenna1: 883 secs ago................... -69 dBm
      HMS2_1F_AP04(slot 1)
        antenna0: 281 secs ago................... -64 dBm
        antenna1: 281 secs ago................... -73 dBm
--More-- or (q)uit
      HMS2_1F_AP02(slot 0)
        antenna0: 279 secs ago................... -65 dBm
        antenna1: 279 secs ago................... -81 dBm
      HMS2_1F_AP02(slot 1)
        antenna0: 281 secs ago................... -80 dBm
        antenna1: 281 secs ago................... -83 dBm
      HMS2_3F_AP03(slot 0)
        antenna0: 279 secs ago................... -75 dBm
        antenna1: 279 secs ago................... -78 dBm
      HMS2_3F_AP02(slot 0)
        antenna0: 279 secs ago................... -83 dBm
        antenna1: 279 secs ago................... -80 dBm
        antenna0: 279 secs ago................... -70 dBm
        antenna1: 279 secs ago................... -71 dBm
        antenna0: 883 secs ago................... -77 dBm
        antenna1: 883 secs ago................... -81 dBm
      HMS2_GF_AP01(slot 1)
        antenna0: 281 secs ago................... -77 dBm
        antenna1: 281 secs ago................... -87 dBm
        antenna0: 279 secs ago................... -68 dBm
--More-- or (q)uit
      HMS2_2F_AP01(slot 1)
        antenna0: 281 secs ago................... -86 dBm
        antenna1: 281 secs ago................... -89 dBm
      HMS2_3F_AP04(slot 1)
        antenna0: 281 secs ago................... -84 dBm
        antenna1: 281 secs ago................... -88 dBm
        antenna0: 279 secs ago................... -34 dBm
        antenna1: 279 secs ago................... -32 dBm
      HMS2_GF_AP05(slot 1)
        antenna0: 281 secs ago................... -49 dBm
        antenna1: 281 secs ago................... -49 dBm
        antenna0: 279 secs ago................... -80 dBm
        antenna1: 279 secs ago................... -74 dBm
      HMS2_GF_AP02(slot 1)
        antenna0: 281 secs ago................... -87 dBm
        antenna1: 281 secs ago................... -80 dBm
        antenna0: 279 secs ago................... -71 dBm
        antenna1: 279 secs ago................... -69 dBm
      HMS2_1F_AP03(slot 1)
--More-- or (q)uit
        antenna0: 281 secs ago................... -85 dBm
        antenna1: 281 secs ago................... -79 dBm
        antenna0: 279 secs ago................... -73 dBm
        antenna1: 279 secs ago................... -87 dBm
      HMS2_1F_AP01(slot 1)
        antenna0: 281 secs ago................... -78 dBm
        antenna1: 281 secs ago................... -82 dBm
        antenna0: 279 secs ago................... -62 dBm
        antenna1: 279 secs ago................... -65 dBm
      HMS2_GF_AP04(slot 1)
        antenna0: 281 secs ago................... -71 dBm
        antenna1: 281 secs ago................... -65 dBm
        antenna0: 883 secs ago................... -78 dBm
        antenna0: 883 secs ago................... -84 dBm
        antenna1: 883 secs ago................... -79 dBm
DNS Server details:
--More-- or (q)uit
(Cisco Controller) >show client detail 4c:34:88:89:88:57                 74:de:2b:fe:81:a3
Client MAC Address............................... 74:de:2b:fe:81:a3
AP MAC Address................................... 1c:e6:c7:85:24:90
AP Name.......................................... HMS1_1F_NW_AP05
BSSID............................................ 1c:e6:c7:85:24:9f
Connected For ................................... 6853 secs
Channel.......................................... 64
Association Id................................... 2
Client CCX version............................... 5
Client E2E version............................... No E2E support
Diagnostics Capability........................... Supported
S69 Capability................................... Not Supported
--More-- or (q)uit
Re-Authentication Timeout........................ 378
Current Rate..................................... 54.0
Audit Session ID................................. 0a1228050014240f564ef950
--More-- or (q)uit
Encryption Cipher................................ TKIP-MIC
      Listen Interval............................ 5
--More-- or (q)uit
Client Statistics:
      Number of Bytes Received................... 5388212
      Number of Bytes Sent....................... 27630166
      Number of Packets Received................. 23181
      Number of Packets Sent..................... 57771
      Number of EAP Key Msg Timeouts............. 3
      Number of Data Retries..................... 1457
--More-- or (q)uit
      Radio Signal Strength Indicator............ -68 dBm
      Signal to Noise Ratio...................... 29 dB
        antenna0: 6863 secs ago.................. -57 dBm
--More-- or (q)uit
        antenna1: 6863 secs ago.................. -53 dBm
      HMS1_2F_NW_AP05(slot 1)
        antenna0: 6863 secs ago.................. -73 dBm
        antenna1: 6863 secs ago.................. -73 dBm
        antenna0: 6863 secs ago.................. -65 dBm
        antenna1: 6863 secs ago.................. -64 dBm
      HMS1_1F_NW_AP04(slot 1)
        antenna0: 6863 secs ago.................. -60 dBm
        antenna1: 6863 secs ago.................. -66 dBm
        antenna0: 6906 secs ago.................. -82 dBm
        antenna1: 6906 secs ago.................. -89 dBm
      HMS1_2F_MR_AP07(slot 1)
        antenna0: 10265 secs ago................. -92 dBm
        antenna1: 10265 secs ago................. -99 dBm
        antenna0: 6909 secs ago.................. -89 dBm
        antenna1: 6909 secs ago.................. -85 dBm
        antenna0: 6863 secs ago.................. -70 dBm
        antenna1: 6863 secs ago.................. -75 dBm
      HMS1_2F_NW_AP06(slot 1)
--More-- or (q)uit
        antenna0: 6862 secs ago.................. -86 dBm
        antenna1: 6862 secs ago.................. -84 dBm
        antenna1: 6863 secs ago.................. -79 dBm
      HMS1_3F_NW_AP02(slot 1)
        antenna0: 12846 secs ago................. -91 dBm
        antenna1: 12846 secs ago................. -96 dBm
        antenna0: 6863 secs ago.................. -83 dBm
        antenna1: 6863 secs ago.................. -91 dBm
        antenna0: 6863 secs ago.................. -71 dBm
        antenna1: 6863 secs ago.................. -70 dBm
      HMS1_2F_SW_AP03(slot 1)
        antenna0: 10568 secs ago................. -94 dBm
        antenna1: 10568 secs ago................. -93 dBm
        antenna0: 6863 secs ago.................. -55 dBm
        antenna1: 6863 secs ago.................. -58 dBm
      HMS1_1F_NW_AP05(slot 1)
        antenna0: 6852 secs ago.................. -66 dBm
        antenna1: 6852 secs ago.................. -71 dBm
--More-- or (q)uit
        antenna0: 6865 secs ago.................. -68 dBm
        antenna1: 6865 secs ago.................. -77 dBm
      HMS1_GF_NW_AP05(slot 1)
        antenna0: 6862 secs ago.................. -80 dBm
        antenna1: 6862 secs ago.................. -92 dBm
        antenna0: 8109 secs ago.................. -90 dBm
        antenna1: 8109 secs ago.................. -91 dBm
        antenna0: 6865 secs ago.................. -78 dBm
        antenna1: 6865 secs ago.................. -81 dBm
      HMS1_2F_NW_AP04(slot 1)
        antenna0: 9068 secs ago.................. -90 dBm
        antenna1: 9068 secs ago.................. -88 dBm
        antenna0: 6866 secs ago.................. -82 dBm
        antenna1: 6866 secs ago.................. -87 dBm
      HMS1_1F_SW_AP01(slot 1)
        antenna0: 10745 secs ago................. -95 dBm
        antenna1: 10745 secs ago................. -94 dBm
        antenna0: 6863 secs ago.................. -89 dBm
--More-- or (q)uit
        antenna1: 6863 secs ago.................. -82 dBm
DNS Server details:
Take a look at the "Current Rate" of the client.  That will show you the rate the client has negotiated with.  To understand the MCS rates, go to the WIRELESS tab on the controller then 802.11a/n/ac then click on High Throughput (802.11n/ac).  This will give you a reference.
-Scott
-Scott
Just to explain this in detail, here is summary of your client speed results
Here are my interpretation.
1). First client 5.5Mbps which 802.11b data rate ( I would suggest you to disable 1.0,2.0,5.5,11.0,6.0,9.0 datarates if you do not have any legacy 802.11b only supported devices).
2.) Second client connected in 2.4GHz with speed of m5 (52Mbps)
3.) Third client connected in 5GHz with speed of m5 (130 Mpbs). This client support AES/CCMP encryption which is required to get 802.11n speed. This client has very good SNR 52 which indicate sits close to AP.
4.) Fourth client connected in 5GHz but limited to 54Mbps as client connected in TKIP instead of AES. ( I would invetigate & see if I can disable TKIP "under WLAN security options" if you do not have client only support TKIP)
Rasika
*** Pls rate all useful responses ***
marc.groenen
Disable B/G mode in your laptop WLAN driver properties to force a connection in A band to see which rate it gets then.
Also please provide more information about the RSSI value's and check which rate's have been enabled globally for B/G and A band.
