01-15-2018 08:22 AM - edited 07-05-2021 08:06 AM
I'm not able to create SNMPv3 user in WLC 8540 with 8.3.133.0 code
GUI says "Error in Creating SNMP V3 User" and CLI says "Could not create v3 user."
Any idea why?
Solved! Go to Solution.
02-21-2018 11:19 PM
Hi Team,
don't know if you guys still facing this issue, solution for the above problem is, create a password of 12 characters for version 3 users in the cisco WLC it will work.
Basavaraj
01-15-2018 08:25 AM
01-31-2018 12:27 AM
Hi everybody,
I have the same issue with the 8.3.132.1 software.
We are working on it and afterwards we will open a case to Cisco.
If we have some extra information we will tell it.
Regards.
01-31-2018 01:15 AM
I remember facing the same issue on 8.0 code and we had to reboot the WLC once to get over it. Did you try rebooting the WLC once ? If that doesn't work , it is probably a bug.
Manish
02-01-2018 11:57 PM
Hi Manish,
Thank you very much for your answer... Unfortunatelly... the device is in production and we can't reboot it on demand... If I could do it I will tell if it is possible or not to create an SNMPv3 user. Anyway we are goint to try to open a case with Cisco.
Best regards.
Jose.
02-21-2018 11:19 PM
Hi Team,
Basavaraj
02-22-2018 01:12 AM
06-10-2018 12:23 PM
So did you open the TAC case ?
If yes, can you share with public the results ?
When and where will it be fixed ?
06-10-2018 11:41 PM
Hi Daniel,
I could not open a TAC case, I am waiting for my company to include the contract of the WLC in my profile. So what we did is to change the password for a one with 12 characters length.
Regards.
06-10-2018 11:43 PM
I tried to create snmpv3 user with 12 characters lengh, but without any success.
