312
Highlighted
Beginner
one SSID broadcasted on one AP but not on a second one
HI, I've searched now everywhere but cannot find a solution.
A customer has 5 SSID's configured and add a new AP on a different site. He want's the same SSID on the new AP but not broadcasted.
With AP groups it's not possible; I can enable or disable the"broadcast" under "WLAN's" --> SSID "Broadcast SSID"
To be sure, the same SSID's!
THX!!!
Stephan
Everyone's tags (5)
1 ACCEPTED SOLUTION
Hall of Fame Master
Re: one SSID broadcasted on one AP but not on a second one
Just to be clear, the two SSIDs will be created the same, one will just have the broadcast enabled and the other will not have broadcasted enabled and the WLAN profile name will be different. Again, this will only work if your WLAN ID for one is 1-16 and the other 17 or higher.
-Scott
9 REPLIES 9
Hall of Fame Master
You need to create another WLAN with a different profile name. Also make sure one of the WLAN IDs is <16 and the other >16. This will allow you to create another SSID with different settings, then you use AP Groups to define which SSID will be used on what AP's.
-Scott
the L2 security will be different though
Hall of Fame Master
Layer 2 can be the same. The work around is using WLAN ID 1-16 and the other >16
-Scott
the WLC will not allow you to configure 2 WLAN with same SSID and same L2 security
http://www.cisco.com/en/US/docs/wireless/controller/7.2/configuration/guide/cg_wlan.html#wp1583666
Hall of Fame Master
That's wrong.... You can! Try it out.
-Scott
i tried it and i got an error , says that i can't creat two WLAN same SSID same L2 security
Hall of Fame Master
Here you go... two SSID's named GuestWiFI with different profile names and one WLAN ID using 6 and the other 17.  The SSID configuraiton is the same for both (layer 2 and 3), one is broadcasting and the other is not.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Hall of Fame Master
-Scott
Beginner
Hi Scott!
Thanks a lot!! I planed to do that with different SSID's, but the information with the WLAN ID is new for me :-)
Thanks for your fast answer!!!
Best regards
Stephan
Content for Community-Ad
August's Community Spotlight Awards
