Option 43 with 5508 redundancy
william.briere
I am looking to use DHCP Option 43 for branch office network connected AP's when I bring them online. I have two controllers I have setup in redundancy mode and want to know if I still need to specify the management IP of each, or can I just specify the redundancy IP?
Controller 5508
Version 7.4.100.0
Access Point 2602
Type AIR-CAP2602I-A-K9
VCI String
Cisco AP c2600
Well that is used for redundancy not ap communication. Console/telnet/ssh to an ap and issue a show capwap client rcb and that will show you what IP address the ap uses to and knows about.
-Scott
Scott Fella
Yes you need to specify the management IP address. The AP's will only connect to the primary WLC not the HA until the primary fails and the HA WLC becomes active.
-Scott
I guess the part I'm confused about is the management IP and the redundancy IP are two different IP's. The redundancy IP is specified on both units. Do I use that one "redundancy IP, or do I leave it off the configuration and instead use the actual management IP's of each controller.
e.g.
Controller#1
Management IP 192.168.10.3
Redundancy IP 192.168.10.2
Controller#2
Management IP 192.168.10.4
-Scott
