09-23-2013 01:41 AM - edited 07-04-2021 12:54 AM
I am trying to select an Outdoor AP for use for extended temperature range -30 + 40. The 1550 series are very good, but as I understand they are only lightweight and require WLC. Is there any other option to go with Cisco? The requirements are
1. Outdoor
2. Temp range -30 + 40
3. Ability to connect omnidirectional antenna (or integrated), the distance to be covered is open area with a radius of 50m.
Best,
Handshake
Solved! Go to Solution.
09-24-2013 11:53 AM
1300 series AP is best suitable according to your need:- outdoor plus the temperature range plus the antennae requirement + autonomous AP
Moreover I could not see anywhere that 1552 Lightweight AP can be converted to Autonomous AP.
so please confirm that part before ordering one and also get the process of conversion before ordering.
09-25-2013 01:19 AM
AFAIK 1300 AP are End of Sale
