08-07-2020 06:08 AM - edited 07-05-2021 12:22 PM
I just upgraded firmware of WLC to 17.3.20200621 but after the upgrade, whenever i login to controller it shows password policy message.
I tried configuring password policy by going to Configuration -> AAA -> AAA Advanced -> Password policy
made one policy but nothing happened
08-07-2020 07:15 AM
- You could also check the flag 'Do not show this message again'
M.
08-07-2020 08:19 AM
08-07-2020 11:21 PM
HI Scott,
New user is created but there is no option of policy tied to specific user.
I logged out from the user and then logged in again from the new user with admin rights but still message is continuously coming.
08-07-2020 11:59 PM
08-08-2020 03:13 AM
Hi @Scott Fella
Are you recommending me to write this command in config mode
"username privilege 15 common-criteria-policy password 0" ??
but how do i specify which user to apply this password policy?
08-08-2020 03:53 PM - edited 08-08-2020 03:56 PM
Some reason the command got filtered:
username (username) privilege 15 common-criteria-policy (policy name) password 0 (password)
Give that a try from the cli and make sure that the show run matches what you entered, if not, then you are running into a bug that is fixed on newer versions.
08-08-2020 03:59 PM
If you see something like this in the show run, then you are hitting the bug:
username <username> privilege 15 common-criteria-policy <policy name> wlan-profile-name password 0 <password>
08-08-2020 01:52 AM
M.
08-08-2020 03:12 AM
Checking the flag is not a solution as i am continuously getting that message again and again
I dont know "why are you saying this thing twice in my post"
08-08-2020 10:12 AM
- As Scott says this is probably a bug in the code , try more recent software version for the controller.
M.
