06-01-2017 04:48 AM - edited 07-05-2021 07:08 AM
Hi All
I've got an old PI installation, which is currently at 3.1.6.
I believe I once, many years ago, have changed the setting for "Maximum VarBinds per Get PDU" which can be found under Administration -> Settings -> System Settings -> Network and Device -> SNMP
Has anybody the default numbers for the Get and Set PDU?
Patrick
Solved! Go to Solution.
11-10-2017 05:09 AM
These are the defaults,
Do you have any good reference explaining its implications and meaning?
11-10-2017 05:09 AM
11-10-2017 07:22 AM
