Power Injector for 1830
AlekseyAndrosov
I am putting together a BOM for a customer.
They require 1830 APs with Power Injectors.
I failed to find any power injectors on cisco.com
Doesn't Cisco manufacture any ? If no, is there a recommended brand ?
Thanks in advance !
Leo Laohoo
AIR-PWRINJ4 will support 1830.  Power draw is for the 1830 is 16.0w and AIR-PWRINJ4 can support up to 20.0w.
Cisco doesn't manufacture the injectors.  The manufacturer of the Cisco-branded power injectors is Phihong USA.
5 Replies 5
mohanak
Powering options
  802.3af/802.3at
  Enhanced PoE
  Cisco local power supply, AIR-PWR-C=
  Cisco power injector, AIR-PWRINJ5= (Note: This injector supports 802.3af only)
Note: If 802.3af PoE is the source of power, the USB port is disabled.
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1830-series-access-points/datasheet-c78-735582.html
"Note: This injector supports 802.3af only"
We want to use all features of 1830, hence 802.3at
Leo Laohoo
Thanks for the info.
http://www.broadbandbuyer.co.uk/products/18401-cisco-air-pwrinj4=/specifications/
Here it says 15W, not 20W. Will you please share, where did you look for the specs of AIR-PWRINJ4 ?
AIR-PWRINJ4 is capable of completely powering up the 1250, 2700 & 3700 and these models require higher than 15.4w PoE.
