Popup Hotspot Using ISR 1000 with WiFi/LTE for Teleworkers and Micro Branchesr
Ask Me Anything – How to Enable Network Connectivity to Remote Workers
4144
Highlighted
Participant
Re: Prevent certain APs from associating with WLC
I see this is an old thread but info still relevant. Didnt see any mention of this as an easy solution. At the default gateway, configure a route for the WLC which you do not want the remote APs to join. Send the next hop to null0. This will make it impossible for the site to contact the WLC IP hence preventing join.
Highlighted
Beginner
You may be able to do this by adding a network route at the WLCs in your org which points to the subnet(s) at the site via a non-existent gateway. All traffic mentioned in network routes should leave the WLC via the Service Port so it should stop APs from being able to connect to the WLC. If it's one subnet it's quick and dirty, but it should work.
Content for Community-Ad
Cisco COVID-19 Survey
