351
Beginner
Prime infrastucture v2.2 to 3.5
I have a prime infrastructure (virtual) v2.2 but I'm going to migrate to v3.5.
if I download a backup of the 2.2 prime this is compatible with v3.5 ???
if so, what happens with the license also comes in the backup ???
How long will it take to download the backup of v2.2 and load it in v3.5 ???
what would be the size of my prime v3.5 (virtual) ???
I add prime feactures.
6 REPLIES 6
Rising star
Re: Prime infrastucture v2.2 to 3.5
Highlighted
Beginner
the first 2.2 I will leave it aside and I will not touch it.
what I will do is create a new virtual machine with version 3.5.
even so first I should go through the 3.1 ??
I believe you can do a fresh install of the PI 3.5, however you can't restore PI 2.2 backup on it.
Please rate if it is helpful.
CJ
Hall of Fame Community Legend
You're better off exporting the DB, stand up a freshly installed PI 3.6 and import the DB.
It is less painful that way.
Beginner
So will the support of PI 2.2 be compatible with the new installation of PI 3.5 ??
VIP Engager
I think/fear you first must upgrade to 3.1 before you can go to 3.5:
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-5/quickstart/guide/bk_Cisco_Prime_Infrastructure_3_5_0_Quick_Start_Guide.html#task_1071048
So my suggestion is:
- create a new VM on 3.0 and restore an application backup (I think) from 2.2
- upgrade the 3.0 installation (with the imported data) to 3.1
- backup the data of the now running 3.1 installation
- create a new VM with 3.5 and import the backup of the 3.1 installation
- install all patches for 3.5 and hope for the best
Depending on how much data you have on 2.2, you maybe want to start from scratch and create a brand new 3.5 or 3.6 installation, add the devices, export the maps information on the 2.2 (if you use them) and import them on your new installation.
The above posted migration path takes at least 1 or 2 days, depending on your database size and the performance of your ESX servers.
Content for Community-Ad
July's Community Spotlight Awards
