06-26-2019 08:11 AM - edited 07-05-2021 10:36 AM
I have a prime infrastructure (virtual) v2.2 but I'm going to migrate to v3.5.
if I download a backup of the 2.2 prime this is compatible with v3.5 ???
if so, what happens with the license also comes in the backup ???
How long will it take to download the backup of v2.2 and load it in v3.5 ???
what would be the size of my prime v3.5 (virtual) ???
I add prime feactures.
06-26-2019 09:47 AM
- Basically this upgrade path is not possibe; you need at least PI3.1 to go to 3.5 :
M.
06-26-2019 10:24 AM
the first 2.2 I will leave it aside and I will not touch it.
what I will do is create a new virtual machine with version 3.5.
even so first I should go through the 3.1 ??
06-26-2019 12:18 PM
I believe you can do a fresh install of the PI 3.5, however you can't restore PI 2.2 backup on it.
Please rate if it is helpful.
CJ
06-27-2019 12:42 AM
06-27-2019 07:37 AM
06-28-2019 01:03 AM
