04-08-2014 01:05 AM - edited 07-05-2021 12:38 AM
Here i my problem... When some clients are connected on 3 SSID'S, 10 or 15 mn after, they are deauthenticated.. and they have to connect again on the SSID.
What is this ReasonCode2 ? there is always a reasonCode but i don't really know the meaning..
Thanks for your answers.
Alexis
10-28-2014 01:53 AM
Have you found a solution for this problem? I am having a similar problem after upgrading to 7.6.130.0 that I get the message "Previous authentication not valid ReasonCode: 2"
But I haven't found any helpful clue on Google... :( Any help is appreciated.
12-01-2014 06:16 AM
No we are still blocked on this issue...
I upgraded my WLC to 8.0. It seems to be ok, i heard nothing about any problems until today :)
Cheers,
05-16-2015 07:39 AM
The meaning of the code is ReasonCode 2: Previous authentication no longer valid (Client associated but not authorized).
09-01-2015 08:32 PM
Dear All,
I am running 8.0.115.0 on 5508 WLC and im still experiencing this issue.
In the WCS i am seeing "Previous Authentication Not Valid". Users disconnect time to time.
Previously I was on 7.4.110.0 and I did not face many issues and the v8 is not stable as 7.4. That was my opinion.
05-07-2015 12:51 AM
Hi Raphael,
We have a similar situation.
WLC5508
version: 7.6.130.0
AP: AIR-CAP2702I-E-K9
Can you confirm that upgrading WLC to 8.0 resolved the "Previous authentication not valid ReasonCode: 2" issue on endpoints?
Hope to get you feedback, thank you in advance.
BR, Ales
05-15-2015 12:09 AM
Hello Ales,
As for me, the upgrade to 8.0 was a solution for this issue.
BUT, be carefull, I had many times the same issue regarding the 8.0 i've installed on some WLCs 5508, the WLCs reboot randomly 1 or times 2 times per week. That's strange because i didn't have this issue for all WLCs i've installed...
Cheers,
AL
07-17-2015 02:15 AM
Which 8.0 version are you running?
We had that issue with 8.0.110 and we could only solved it after upgrading to 8.0.110.6 or 8.0.110.9.
Cheers,
Vasco
07-17-2015 03:13 AM
Hello Vasco,
I am running version 8.0.115.0, Cisco proposed me the 8.0.110.9 code but i didn't test it. But i had another issue, i got some random reboots for 2 customers who have the 5508 model (sometimes it was 1 time per week, sometimes it was 3 times...) , then i went back to 7.6.130.0 which is more stable (as for me).
Did you use the "debug client <MAC address>" command over CLI to troubleshoot ? It really helps me when some clients are facing disconnection issues.
Hope this helps,
Cheers,
Alexis
10-27-2017 08:07 AM
This is caused because the memory reach the threshold permitted. ~89%. The memory is increased because CDP, you can disable it and the problem would be solved. If this is no the cause of the problem do a show process and see which is consuming more memory.
