02-12-2014 06:56 AM - edited 07-05-2021 12:10 AM
Hi eveybody.
I'm having a problem when i try to connect to a WLAN with any gadget. There's no problem when i try to connect from my laptop. Problem only exists when i try to use any of the devices mentioned.
This is a guest WLAN, which it has been hidden, now i enbaled the broadcast SSID. i already tried to create another one, but still having the same problem when i try to connect from the gadgets.
I thought that maybe it was a problem with the encryption (WPA2-PSK), but gadgets can connect to another WLAN in the same WLC 5508
without a problem.
I already changed the encryption type, even i let it opened, but nothing worked for me.
I don't know if i'm missing something, i really hope you can help me.
Thanks in advance!
Regards.
02-12-2014 08:07 AM
Post your show wlan
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
02-12-2014 11:17 AM
Hi Scott!
Mmhh, idk if i'm doing something wrong. this is the output i get of show wlan
(Cisco Controller) >show wlan
HELP:
Special keys:
DEL, BS .... delete previous character
Ctrl-A .... go to beginning of line
Ctrl-E .... go to end of line
Ctrl-F .... go forward one character
Ctrl-B .... go backward one character
Ctrl-D .... delete current character
Ctrl-U, X .. delete to beginning of line
Ctrl-K .... delete to end of line
Ctrl-W .... delete previous word
Ctrl-T .... transpose previous character
Ctrl-P .... go to previous line in history buffer
Ctrl-N .... go to next line in history buffer
Ctrl-Z .... return to root command prompt
Tab,
Exit .... go to next lower command prompt
? .... list choices
02-12-2014 08:17 AM
Enrique,
Also, get us the client debug from the WLC, when the device is not able to join ..
1) Enable "debug client
2) Try to associate the client..
Get the complete debug output..
Victor V
*****Help out other by using the rating system and marking answered questions as *****Answered"*****
02-12-2014 11:33 AM
(Cisco Controller) >debug client DC:9B:9C:3E:06:6F
(Cisco Controller) >*DHCP Socket Task: Feb 12 13:25:19.428: a8:bb:cf:18:28:50 DHCP dropping looped REQUEST from DS
(encap type 0xec00)
*apfMsConnTask_5: Feb 12 13:27:05.533: dc:9b:9c:3e:06:6f Association received from mobile on AP f4:7f:35:05:e6:10
*apfMsConnTask_5: Feb 12 13:27:05.533: dc:9b:9c:3e:06:6f Deleting client immediately since WLAN has changed
*apfMsConnTask_5: Feb 12 13:27:05.533: dc:9b:9c:3e:06:6f Scheduling deletion of Mobile Station: (callerId: 50) in 1
seconds
*apfMsConnTask_5: Feb 12 13:27:05.845: dc:9b:9c:3e:06:6f Ignoring 802.11 assoc request from mobile pending deletion
*apfMsConnTask_5: Feb 12 13:27:05.845: dc:9b:9c:3e:06:6f Sending Assoc Response to station on BSSID f4:7f:35:05:e6:10
(status 12) ApVapId 2 Slot 1
*apfMsConnTask_6: Feb 12 13:27:05.894: dc:9b:9c:3e:06:6f Ignoring 802.11 assoc request from mobile pending deletion
*apfMsConnTask_6: Feb 12 13:27:05.894: dc:9b:9c:3e:06:6f Sending Assoc Response to station on BSSID f4:7f:35:05:e5:b0
(status 12) ApVapId 2 Slot 0
*apfMsConnTask_6: Feb 12 13:27:05.956: dc:9b:9c:3e:06:6f Ignoring 802.11 assoc request from mobile pending deletion
*apfMsConnTask_6: Feb 12 13:27:05.956: dc:9b:9c:3e:06:6f Sending Assoc Response to station on BSSID f4:7f:35:05:e5:b0
*apfMsConnTask_5: Feb 12 13:27:06.411: dc:9b:9c:3e:06:6f Ignoring 802.11 assoc request from mobile pending deletion
*apfMsConnTask_5: Feb 12 13:27:06.411: dc:9b:9c:3e:06:6f Sending Assoc Response to station on BSSID f4:7f:35:05:e6:10
(status 12) ApVapId 4 Slot 1
*apfMsConnTask_5: Feb 12 13:27:06.437: dc:9b:9c:3e:06:6f Ignoring 802.11 assoc request from mobile pending deletion
*apfMsConnTask_5: Feb 12 13:27:06.437: dc:9b:9c:3e:06:6f Sending Assoc Response to station on BSSID f4:7f:35:05:e6:10
(status 12) ApVapId 4 Slot 0
*apfMsConnTask_6: Feb 12 13:27:06.471: dc:9b:9c:3e:06:6f Ignoring 802.11 assoc request from mobile pending deletion
*apfMsConnTask_6: Feb 12 13:27:06.471: dc:9b:9c:3e:06:6f Sending Assoc Response to station on BSSID f4:7f:35:05:e5:b0
*osapiBsnTimer: Feb 12 13:27:06.527: dc:9b:9c:3e:06:6f apfMsExpireCallback (apf_ms.c:589) Expiring Mobile!
*apfReceiveTask: Feb 12 13:27:06.528: dc:9b:9c:3e:06:6f apfMsExpireMobileStation (apf_ms.c:5584) Changing state for
mobile dc:9b:9c:3e:06:6f on AP f4:7f:35:05:e6:10 from Associated to Disassociated
*apfReceiveTask: Feb 12 13:27:06.529: dc:9b:9c:3e:06:6f Sent Deauthenticate to mobile on BSSID f4:7f:35:05:e6:10 slot
1(caller apf_ms.c:5678)
*apfReceiveTask: Feb 12 13:27:06.529: dc:9b:9c:3e:06:6f apfMsAssoStateDec
*apfReceiveTask: Feb 12 13:27:06.529: dc:9b:9c:3e:06:6f apfMsExpireMobileStation (apf_ms.c:5716) Changing state for
mobile dc:9b:9c:3e:06:6f on AP f4:7f:35:05:e6:10 from Disassociated to Idle
*apfReceiveTask: Feb 12 13:27:06.529: dc:9b:9c:3e:06:6f pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE =
0.
*apfReceiveTask: Feb 12 13:27:06.529: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) Deleted mobile LWAPP rule on AP
[f4:7f:35:05:e6:10]
*apfReceiveTask: Feb 12 13:27:06.529: dc:9b:9c:3e:06:6f apfMsRunStateDec
*apfReceiveTask: Feb 12 13:27:06.529: dc:9b:9c:3e:06:6f apfMs1xStateDec
*apfReceiveTask: Feb 12 13:27:06.529: dc:9b:9c:3e:06:6f Deleting mobile on AP f4:7f:35:05:e6:10(1)
*pemReceiveTask: Feb 12 13:27:06.531: dc:9b:9c:3e:06:6f 172.16.9.163 Removed NPU entry.
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f Adding mobile on LWAPP AP f4:7f:35:05:e5:b0(0)
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f Association received from mobile on AP f4:7f:35:05:e5:b0
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f 0.0.0.0 START (0) Changing IPv4 ACL 'none' (ACL ID 255) ===>
'none' (ACL ID 255) --- (caller apf_policy.c:1697)
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f 0.0.0.0 START (0) Changing IPv6 ACL 'none' (ACL ID 255) ===>
'none' (ACL ID 255) --- (caller apf_policy.c:1864)
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f Applying site-specific Local Bridging override for station
dc:9b:9c:3e:06:6f - vapId 4, site 'default-group', interface 'treswts'
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f Applying Local Bridging Interface Policy for station
dc:9b:9c:3e:06:6f - vlan 9, interface id 14, interface 'treswts'
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f processSsidIE statusCode is 0 and status is 0
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f processSsidIE ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f STA - rates (8): 130 132 139 150 36 48 72 108 0 0 0 0 0 0 0 0
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f suppRates statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f STA - rates (12): 130 132 139 150 36 48 72 108 12 18 24 96 0
0 0 0
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f extSuppRates statusCode is 0 and gotExtSuppRatesElement is 1
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f Processing RSN IE type 48, length 20 for mobile
dc:9b:9c:3e:06:6f
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f 0.0.0.0 START (0) Initializing policy
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f 0.0.0.0 START (0) Change state to AUTHCHECK (2) last state
AUTHCHECK (2)
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f 0.0.0.0 AUTHCHECK (2) Change state to 8021X_REQD (3) last
state 8021X_REQD (3)
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f 0.0.0.0 8021X_REQD (3) DHCP Not required on AP
f4:7f:35:05:e5:b0 vapId 4 apVapId 4for this client
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f Not Using WMM Compliance code qosCap 00
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f 0.0.0.0 8021X_REQD (3) Plumbed mobile LWAPP rule on AP
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f apfMsAssoStateInc
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f apfPemAddUser2 (apf_policy.c:268) Changing state for mobile
dc:9b:9c:3e:06:6f on AP f4:7f:35:05:e5:b0 from Idle to Associated
*apfMsConnTask_6: Feb 12 13:27:07.026: dc:9b:9c:3e:06:6f Scheduling deletion of Mobile Station: (callerId: 49) in
1800 seconds
*apfMsConnTask_6: Feb 12 13:27:07.027: dc:9b:9c:3e:06:6f Sending Assoc Response to station on BSSID f4:7f:35:05:e5:b0
(status 0) ApVapId 4 Slot 0
*apfMsConnTask_6: Feb 12 13:27:07.027: dc:9b:9c:3e:06:6f apfProcessAssocReq (apf_80211.c:6290) Changing state for
mobile dc:9b:9c:3e:06:6f on AP f4:7f:35:05:e5:b0 from Associated to Associated
*dot1xMsgTask: Feb 12 13:27:07.031: dc:9b:9c:3e:06:6f Creating a PKC PMKID Cache entry for station dc:9b:9c:3e:06:6f
(RSN 2)
*dot1xMsgTask: Feb 12 13:27:07.031: dc:9b:9c:3e:06:6f Resetting MSCB PMK Cache Entry 0 for station dc:9b:9c:3e:06:6f
*dot1xMsgTask: Feb 12 13:27:07.031: dc:9b:9c:3e:06:6f Setting active key cache index 8 ---> 8
*dot1xMsgTask: Feb 12 13:27:07.031: dc:9b:9c:3e:06:6f Setting active key cache index 8 ---> 0
*dot1xMsgTask: Feb 12 13:27:07.031: dc:9b:9c:3e:06:6f Adding BSSID f4:7f:35:05:e5:b3 to PMKID cache at index 0 for
*dot1xMsgTask: Feb 12 13:27:07.031: New PMKID: (16)
*dot1xMsgTask: Feb 12 13:27:07.031: [0000] 44 07 fe 3d d3 87 da 29 b8 e0 8a 43 d2 b5 0b f4
*dot1xMsgTask: Feb 12 13:27:07.031: dc:9b:9c:3e:06:6f Initiating RSN PSK to mobile dc:9b:9c:3e:06:6f
*dot1xMsgTask: Feb 12 13:27:07.031: dc:9b:9c:3e:06:6f dot1x - moving mobile dc:9b:9c:3e:06:6f into Force Auth state
*dot1xMsgTask: Feb 12 13:27:07.031: dc:9b:9c:3e:06:6f Skipping EAP-Success to mobile dc:9b:9c:3e:06:6f
*dot1xMsgTask: Feb 12 13:27:07.031: dc:9b:9c:3e:06:6f Found an cache entry for BSSID f4:7f:35:05:e5:b3 in PMKID cache
at index 0 of station dc:9b:9c:3e:06:6f
*dot1xMsgTask: Feb 12 13:27:07.031: Including PMKID in M1 (16)
*dot1xMsgTask: Feb 12 13:27:07.031: dc:9b:9c:3e:06:6f Starting key exchange to mobile dc:9b:9c:3e:06:6f, data packets
will be dropped
*dot1xMsgTask: Feb 12 13:27:07.031: dc:9b:9c:3e:06:6f Sending EAPOL-Key Message to mobile dc:9b:9c:3e:06:6f
state
INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00
*Dot1x_NW_MsgTask_7: Feb 12 13:27:07.037: dc:9b:9c:3e:06:6f Received EAPOL-Key from mobile dc:9b:9c:3e:06:6f
*Dot1x_NW_MsgTask_7: Feb 12 13:27:07.037: dc:9b:9c:3e:06:6f Received EAPOL-key in PTK_START state (message 2) from
*Dot1x_NW_MsgTask_7: Feb 12 13:27:07.037: dc:9b:9c:3e:06:6f Stopping retransmission timer for mobile dc:9b:9c:3e:06:6f
*Dot1x_NW_MsgTask_7: Feb 12 13:27:07.037: dc:9b:9c:3e:06:6f Sending EAPOL-Key Message to mobile dc:9b:9c:3e:06:6f
state PTKINITNEGOTIATING (message 3), replay counter 00.00.00.00.00.00.00.01
*Dot1x_NW_MsgTask_7: Feb 12 13:27:07.045: dc:9b:9c:3e:06:6f Received EAPOL-Key from mobile dc:9b:9c:3e:06:6f
*Dot1x_NW_MsgTask_7: Feb 12 13:27:07.045: dc:9b:9c:3e:06:6f Received EAPOL-key in PTKINITNEGOTIATING state (message 4)
*Dot1x_NW_MsgTask_7: Feb 12 13:27:07.045: dc:9b:9c:3e:06:6f apfMs1xStateInc
*Dot1x_NW_MsgTask_7: Feb 12 13:27:07.045: dc:9b:9c:3e:06:6f 0.0.0.0 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4)
last state L2AUTHCOMPLETE (4)
*Dot1x_NW_MsgTask_7: Feb 12 13:27:07.045: dc:9b:9c:3e:06:6f 0.0.0.0 L2AUTHCOMPLETE (4) DHCP Not required on AP
*Dot1x_NW_MsgTask_7: Feb 12 13:27:07.045: dc:9b:9c:3e:06:6f Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_7: Feb 12 13:27:07.045: dc:9b:9c:3e:06:6f 0.0.0.0 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP
*Dot1x_NW_MsgTask_7: Feb 12 13:27:07.045: dc:9b:9c:3e:06:6f 0.0.0.0 L2AUTHCOMPLETE (4) Change state to DHCP_REQD (7)
last state DHCP_REQD (7)
*Dot1x_NW_MsgTask_7: Feb 12 13:27:07.045: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) pemAdvanceState2 5253, Adding TMP
rule
*Dot1x_NW_MsgTask_: Feb 12 13:27:07.045: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) Adding Fast Path rule
type = Airespace AP - Learn IP address
on AP f4:7f:35:05:e5:b0, slot 0, interface = 1, QOS = 0
IPv4 ACL ID = 255, IPv
*Dot1x_NW_MsgTask_7: Feb 12 13:27:07.045: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) Fast Path rule (contd...) 802.1P =
0, DSCP = 0, TokenID = 7006 Local Bridging Vlan = 9, Local Bridging intf id = 14
*Dot1x_NW_MsgTask_7: Feb 12 13:27:07.045: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) Successfully plumbed mobile rule
(IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_7: Feb 12 13:27:07.045: dc:9b:9c:3e:06:6f Stopping retransmission timer for mobile dc:9b:9c:3e:06:6f
*pemReceiveTask: Feb 12 13:27:07.046: dc:9b:9c:3e:06:6f 0.0.0.0 Added NPU entry of type 9, dtlFlags 0x0
*pemReceiveTask: Feb 12 13:27:07.046: dc:9b:9c:3e:06:6f Sent an XID frame
*IPv6_Msg_Task: Feb 12 13:27:07.088: dc:9b:9c:3e:06:6f Pushing IPv6: fe80:0000:0000:0000: 1017:eb84:7c42:0b6a , and
MAC: DC:9B:9C:3E:06:6F , Binding to Data Plane. SUCCESS !!
*apfOrphanSocketTask: Feb 12 13:27:07.894: dc:9b:9c:3e:06:6f Orphan Packet from DS - IP 172.16.9.163
*pemReceiveTask: Feb 12 13:27:07.895: dc:9b:9c:3e:06:6f 0.0.0.0 Removed NPU entry.
*DHCP Socket Task: Feb 12 13:27:08.891: dc:9b:9c:3e:06:6f DHCP received op BOOTREQUEST (1) (len 308,vlan 5, port 1,
encap 0xec03)
*DHCP Socket Task: Feb 12 13:27:08.892: dc:9b:9c:3e:06:6f DHCP dropping packet due to ongoing mobility handshake
exchange, (siaddr 0.0.0.0, mobility state = 'apfMsMmQueryRequested'
*apfReceiveTask: Feb 12 13:27:09.928: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) State Update from Mobility-Incomplete to
Mobility-Complete, mobility role=Local, client state=APF_MS_STATE_ASSOCIATED
*apfReceiveTask: Feb 12 13:27:09.928: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) pemAdvanceState2 4891, Adding TMP rule
*apfReceiveTask: Feb 12 13:27:09.928: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) Adding Fast Path rule
*apfReceiveTask: Feb 12 13:27:09.928: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) Fast Path rule (contd...) 802.1P = 0,
*apfReceiveTask: Feb 12 13:27:09.928: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) Successfully plumbed mobile rule (IPv4
*apfReceiveTask: Feb 12 13:27:09.928: dc:9b:9c:3e:06:6f IPv6 client got an IPv6 addresses, continue the PEM process
*apfReceiveTask: Feb 12 13:27:09.928: dc:9b:9c:3e:06:6f apfMsRunStateInc
*apfReceiveTask: Feb 12 13:27:09.928: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) Change state to RUN (20) last state RUN
(20)
*apfReceiveTask: Feb 12 13:27:09.929: dc:9b:9c:3e:06:6f 0.0.0.0 RUN (20) Reached PLUMBFASTPATH: from line 5776
*apf: Feb 12 13:27:09.929: dc:9b:9c:3e:06:6f 0.0.0.0 RUN (20) Replacing Fast Path rule
type = Airespace AP Client
IPv4 ACL ID = 255, IPv6 ACL ID = 255
*apfReceiveTask: Feb 12 13:27:09.929: dc:9b:9c:3e:06:6f 0.0.0.0 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP =
*apfReceiveTask: Feb 12 13:27:09.929: dc:9b:9c:3e:06:6f 0.0.0.0 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID
*pemReceiveTask: Feb 12 13:27:09.930: dc:9b:9c:3e:06:6f 0.0.0.0 Added NPU entry of type 9, dtlFlags 0x0
*pemReceiveTask: Feb 12 13:27:09.930: dc:9b:9c:3e:06:6f Sent an XID frame
*pemReceiveTask: Feb 12 13:27:09.930: dc:9b:9c:3e:06:6f 0.0.0.0 Added NPU entry of type 1, dtlFlags 0x0
*pemReceiveTask: Feb 12 13:27:09.931: dc:9b:9c:3e:06:6f Pushing IPv6: fe80:0000:0000:0000: 1017:eb84:7c42:0b6a , and
*pemReceiveTask: Feb 12 13:27:09.931: dc:9b:9c:3e:06:6f 0.0.0.0, VLAN Id 9 Not sending gratuitous ARP
*DHCP Socket Task: Feb 12 13:27:11.432: dc:9b:9c:3e:06:6f DHCP received op BOOTREQUEST (1) (len 308,vlan 5, port 1,
encap 0xec03)
*DHCP Socket Task: Feb 12 13:27:11.432: dc:9b:9c:3e:06:6f DHCP processing DHCP REQUEST (3)
*DHCP Socket Task: Feb 12 13:27:11.432: dc:9b:9c:3e:06:6f DHCP op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Feb 12 13:27:11.432: dc:9b:9c:3e:06:6f DHCP xid: 0x3b5d3074 (995962996), secs: 5, flags: 0
*DHCP Socket Task: Feb 12 13:27:11.432: dc:9b:9c:3e:06:6f DHCP chaddr: dc:9b:9c:3e:06:6f
*DHCP Socket Task: Feb 12 13:27:11.432: dc:9b:9c:3e:06:6f DHCP ciaddr: 0.0.0.0, yiaddr: 0.0.0.0
*DHCP Socket Task: Feb 12 13:27:11.433: dc:9b:9c:3e:06:6f DHCP siaddr: 0.0.0.0, giaddr: 0.0.0.0
*DHCP Socket Task: Feb 12 13:27:11.433: dc:9b:9c:3e:06:6f DHCP requested ip: 172.16.9.163
*DHCP Socket Task: Feb 12 13:27:11.433: dc:9b:9c:3e:06:6f DHCP successfully bridged packet to DS
*DHCP Socket Task: Feb 12 13:27:11.434: dc:9b:9c:3e:06:6f DHCP received op BOOTREPLY (2) (len 308,vlan 9, port 1,
encap 0xec00)
*DHCP Socket Task: Feb 12 13:27:11.434: dc:9b:9c:3e:06:6f DHCP processing DHCP ACK (5)
*DHCP Socket Task: Feb 12 13:27:11.434: dc:9b:9c:3e:06:6f DHCP op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Feb 12 13:27:11.434: dc:9b:9c:3e:06:6f DHCP xid: 0x3b5d3074 (995962996), secs: 0, flags: 0
*DHCP Socket Task: Feb 12 13:27:11.434: dc:9b:9c:3e:06:6f DHCP chaddr: dc:9b:9c:3e:06:6f
*DHCP Socket Task: Feb 12 13:27:11.434: dc:9b:9c:3e:06:6f DHCP ciaddr: 0.0.0.0, yiaddr: 172.16.9.163
*DHCP Socket Task: Feb 12 13:27:11.434: dc:9b:9c:3e:06:6f DHCP siaddr: 0.0.0.0, giaddr: 0.0.0.0
*DHCP Socket Task: Feb 12 13:27:11.434: dc:9b:9c:3e:06:6f DHCP server id: 172.16.9.1 rcvd server id: 172.16.9.1
*DHCP Socket Task: Feb 12 13:27:11.434: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) DHCP Address Re-established
*DHCP Socket Task: Feb 12 13:27:11.434: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) Reached PLUMBFASTPATH: from line 6091
*DHCP Soc: Feb 12 13:27:11.434: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) Replacing Fast Path rule
*DHCP Socket Task: Feb 12 13:27:11.434: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) Fast Path rule (contd...) 802.1P = 0,
*DHCP Socket Task: Feb 12 13:27:11.434: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) Successfully plumbed mobile rule (IPv4
*DHCP Socket Task: Feb 12 13:27:11.434: dc:9b:9c:3e:06:6f Assigning Address 172.16.9.163 to mobile
*DHCP Socket Task: Feb 12 13:27:11.434: dc:9b:9c:3e:06:6f DHCP success event for client. Clearing dhcp failure count
for interface treswts.
*DHCP Socket Task: Feb 12 13:27:11.434: dc:9b:9c:3e:06:6f DHCP successfully bridged packet to STA
*pemReceiveTask: Feb 12 13:27:11.436: dc:9b:9c:3e:06:6f 172.16.9.163 Added NPU entry of type 1, dtlFlags 0x0
*pemReceiveTask: Feb 12 13:27:11.436: dc:9b:9c:3e:06:6f Pushing IPv6: fe80:0000:0000:0000: 1017:eb84:7c42:0b6a , and
*apfMsConnTask_6: Feb 12 13:27:15.869: dc:9b:9c:3e:06:6f Reassociation received from mobile on AP f4:7f:35:05:e5:b0
*apfMsConnTask_6: Feb 12 13:27:15.869: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255)
===> 'none' (ACL ID 255) --- (caller apf_policy.c:1697)
*apfMsConnTask_6: Feb 12 13:27:15.869: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255)
===> 'none' (ACL ID 255) --- (caller apf_policy.c:1864)
*apfMsConnTask_6: Feb 12 13:27:15.869: dc:9b:9c:3e:06:6f Applying site-specific Local Bridging override for station
*apfMsConnTask_6: Feb 12 13:27:15.869: dc:9b:9c:3e:06:6f Applying Local Bridging Interface Policy for station
*apfMsConnTask_6: Feb 12 13:27:15.869: dc:9b:9c:3e:06:6f processSsidIE statusCode is 0 and status is 0
*apfMsConnTask_6: Feb 12 13:27:15.869: dc:9b:9c:3e:06:6f processSsidIE ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_6: Feb 12 13:27:15.869: dc:9b:9c:3e:06:6f STA - rates (8): 140 18 152 36 176 72 96 108 12 18 24 96 0 0
0 0
*apfMsConnTask_6: Feb 12 13:27:15.869: dc:9b:9c:3e:06:6f suppRates statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_6: Feb 12 13:27:15.870: dc:9b:9c:3e:06:6f Processing RSN IE type 48, length 20 for mobile
dc:9b:9c:3e:06:6f
*apfMsConnTask_6: Feb 12 13:27:15.870: dc:9b:9c:3e:06:6f pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE
= 0.
*apfMsConnTask_6: Feb 12 13:27:15.870: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) Deleted mobile LWAPP rule on AP
[f4:7f:35:05:e5:b0]
*apfMsConnTask_6: Feb 12 13:27:15.870: dc:9b:9c:3e:06:6f Updated location for station old AP f4:7f:35:05:e5:b0-0, new
AP f4:7f:35:05:e5:b0-1
*apfMsConnTask_6: Feb 12 13:27:15.870: dc:9b:9c:3e:06:6f apfMsRunStateDec
*apfMsConnTask_6: Feb 12 13:27:15.870: dc:9b:9c:3e:06:6f apfMs1xStateDec
*apfMsConnTask_6: Feb 12 13:27:15.870: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) Change state to START (0) last state
RUN (20)
*apfMsConnTask_6: Feb 12 13:27:15.870: dc:9b:9c:3e:06:6f pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE =
0.
*apfMsConnTask_6: Feb 12 13:27:15.870: dc:9b:9c:3e:06:6f 172.16.9.163 START (0) Initializing policy
*apfMsConnTask_6: Feb 12 13:27:15.870: dc:9b:9c:3e:06:6f 172.16.9.163 START (0) Change state to AUTHCHECK (2) last
state RUN (20)
*apfMsConnTask_6: Feb 12 13:27:15.870: dc:9b:9c:3e:06:6f 172.16.9.163 AUTHCHECK (2) Change state to 8021X_REQD (3)
last state RUN (20)
*apfMsConnTask_6: Feb 12 13:27:15.870: dc:9b:9c:3e:06:6f 172.16.9.163 8021X_REQD (3) DHCP required on AP
*apfMsConnTask_6: Feb 12 13:27:15.870: dc:9b:9c:3e:06:6f Not Using WMM Compliance code qosCap 00
*apfMsConnTask_6: Feb 12 13:27:15.870: dc:9b:9c:3e:06:6f 172.16.9.163 8021X_REQD (3) Plumbed mobile LWAPP rule on AP
*apfMsConnTask_6: Feb 12 13:27:15.870: dc:9b:9c:3e:06:6f apfPemAddUser2 (apf_policy.c:268) Changing state for mobile
*apfMsConnTask_6: Feb 12 13:27:15.870: dc:9b:9c:3e:06:6f Scheduling deletion of Mobile Station: (callerId: 49) in
1800 seconds
*apfMsConnTask_6: Feb 12 13:27:15.870: dc:9b:9c:3e:06:6f Sending Assoc Response to station on BSSID f4:7f:35:05:e5:b0
(status 0) ApVapId 4 Slot 1
*apfMsConnTask_6: Feb 12 13:27:15.870: dc:9b:9c:3e:06:6f apfProcessAssocReq (apf_80211.c:6290) Changing state for
*pemReceiveTask: Feb 12 13:27:15.873: dc:9b:9c:3e:06:6f 172.16.9.163 Removed NPU entry.
*dot1xMsgTask: Feb 12 13:27:15.876: dc:9b:9c:3e:06:6f Creating a PKC PMKID Cache entry for station dc:9b:9c:3e:06:6f
(RSN 2)
*dot1xMsgTask: Feb 12 13:27:15.876: dc:9b:9c:3e:06:6f Resetting MSCB PMK Cache Entry 0 for station dc:9b:9c:3e:06:6f
*dot1xMsgTask: Feb 12 13:27:15.876: dc:9b:9c:3e:06:6f Removing BSSID f4:7f:35:05:e5:b3 from PMKID cache of station
dc:9b:9c:3e:06:6f
*dot1xMsgTask: Feb 12 13:27:15.876: dc:9b:9c:3e:06:6f Setting active key cache index 0 ---> 8
*dot1xMsgTask: Feb 12 13:27:15.876: dc:9b:9c:3e:06:6f Setting active key cache index 8 ---> 0
*dot1xMsgTask: Feb 12 13:27:15.876: dc:9b:9c:3e:06:6f Adding BSSID f4:7f:35:05:e5:bc to PMKID cache at index 0 for
*dot1xMsgTask: Feb 12 13:27:15.876: New PMKID: (16)
*dot1xMsgTask: Feb 12 13:27:15.876: [0000] df b2 42 72 6b d8 3f ab 9e 72 94 54 72 24 fd 3d
*dot1xMsgTask: Feb 12 13:27:15.876: dc:9b:9c:3e:06:6f Initiating RSN PSK to mobile dc:9b:9c:3e:06:6f
*dot1xMsgTask: Feb 12 13:27:15.876: dc:9b:9c:3e:06:6f dot1x - moving mobile dc:9b:9c:3e:06:6f into Force Auth state
*dot1xMsgTask: Feb 12 13:27:15.876: dc:9b:9c:3e:06:6f Skipping EAP-Success to mobile dc:9b:9c:3e:06:6f
*dot1xMsgTask: Feb 12 13:27:15.876: dc:9b:9c:3e:06:6f Found an cache entry for BSSID f4:7f:35:05:e5:bc in PMKID cache
*dot1xMsgTask: Feb 12 13:27:15.876: Including PMKID in M1 (16)
*dot1xMsgTask: Feb 12 13:27:15.876: dc:9b:9c:3e:06:6f Starting key exchange to mobile dc:9b:9c:3e:06:6f, data packets
will be dropped
*dot1xMsgTask: Feb 12 13:27:15.876: dc:9b:9c:3e:06:6f Sending EAPOL-Key Message to mobile dc:9b:9c:3e:06:6f
state
*Dot1x_NW_MsgTask_7: Feb 12 13:27:15.886: dc:9b:9c:3e:06:6f Received EAPOL-Key from mobile dc:9b:9c:3e:06:6f
*Dot1x_NW_MsgTask_7: Feb 12 13:27:15.886: dc:9b:9c:3e:06:6f Received EAPOL-key in PTK_START state (message 2) from
*Dot1x_NW_MsgTask_7: Feb 12 13:27:15.886: dc:9b:9c:3e:06:6f Stopping retransmission timer for mobile dc:9b:9c:3e:06:6f
*Dot1x_NW_MsgTask_7: Feb 12 13:27:15.886: dc:9b:9c:3e:06:6f Sending EAPOL-Key Message to mobile dc:9b:9c:3e:06:6f
*Dot1x_NW_MsgTask_7: Feb 12 13:27:15.888: dc:9b:9c:3e:06:6f Received EAPOL-Key from mobile dc:9b:9c:3e:06:6f
*Dot1x_NW_MsgTask_7: Feb 12 13:27:15.888: dc:9b:9c:3e:06:6f Received EAPOL-key in PTKINITNEGOTIATING state (message 4)
*Dot1x_NW_MsgTask_7: Feb 12 13:27:15.888: dc:9b:9c:3e:06:6f apfMs1xStateInc
*Dot1x_NW_MsgTask_7: Feb 12 13:27:15.888: dc:9b:9c:3e:06:6f 172.16.9.163 8021X_REQD (3) Change state to L2AUTHCOMPLETE
(4) last state RUN (20)
*Dot1x_NW_MsgTask_7: Feb 12 13:27:15.888: dc:9b:9c:3e:06:6f 172.16.9.163 L2AUTHCOMPLETE (4) DHCP required on AP
*Dot1x_NW_MsgTask_7: Feb 12 13:27:15.888: dc:9b:9c:3e:06:6f Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_7: Feb 12 13:27:15.888: dc:9b:9c:3e:06:6f 172.16.9.163 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule
on AP f4:7f:35:05:e5:b0 vapId 4 apVapId 4
*Dot1x_NW_MsgTask_7: Feb 12 13:27:15.888: dc:9b:9c:3e:06:6f apfMsRunStateInc
*Dot1x_NW_MsgTask_7: Feb 12 13:27:15.888: dc:9b:9c:3e:06:6f 172.16.9.163 L2AUTHCOMPLETE (4) Change state to RUN (20)
last state RUN (20)
*Dot1x_NW_MsgTask_7: Feb 12 13:27:15.889: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) Reached PLUMBFASTPATH: from line
5362
*Dot1x: Feb 12 13:27:15.889: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) Adding Fast Path rule
on AP f4:7f:35:05:e5:b0, slot 1, interface = 1, QOS = 0
*Dot1x_NW_MsgTask_7: Feb 12 13:27:15.889: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) Fast Path rule (contd...) 802.1P =
*Dot1x_NW_MsgTask_7: Feb 12 13:27:15.889: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) Successfully plumbed mobile rule
*Dot1x_NW_MsgTask_7: Feb 12 13:27:15.889: dc:9b:9c:3e:06:6f Stopping retransmission timer for mobile dc:9b:9c:3e:06:6f
*pemReceiveTask: Feb 12 13:27:15.890: dc:9b:9c:3e:06:6f 172.16.9.163 Added NPU entry of type 1, dtlFlags 0x0
*pemReceiveTask: Feb 12 13:27:15.890: dc:9b:9c:3e:06:6f Pushing IPv6: fe80:0000:0000:0000: 1017:eb84:7c42:0b6a , and
*apfMsConnTask_6: Feb 12 13:27:20.186: dc:9b:9c:3e:06:6f Association received from mobile on AP f4:7f:35:05:e5:b0
*apfMsConnTask_6: Feb 12 13:27:20.186: dc:9b:9c:3e:06:6f Deleting client immediately since WLAN has changed
*apfMsConnTask_6: Feb 12 13:27:20.186: dc:9b:9c:3e:06:6f Scheduling deletion of Mobile Station: (callerId: 50) in 1
seconds
*apfMsConnTask_6: Feb 12 13:27:20.498: dc:9b:9c:3e:06:6f Ignoring 802.11 assoc request from mobile pending deletion
*apfMsConnTask_6: Feb 12 13:27:20.498: dc:9b:9c:3e:06:6f Sending Assoc Response to station on BSSID f4:7f:35:05:e5:b0
*apfMsConnTask_5: Feb 12 13:27:20.511: dc:9b:9c:3e:06:6f Ignoring 802.11 assoc request from mobile pending deletion
*apfMsConnTask_5: Feb 12 13:27:20.512: dc:9b:9c:3e:06:6f Sending Assoc Response to station on BSSID f4:7f:35:05:e6:10
*apfMsConnTask_5: Feb 12 13:27:20.569: dc:9b:9c:3e:06:6f Ignoring 802.11 assoc request from mobile pending deletion
*apfMsConnTask_5: Feb 12 13:27:20.569: dc:9b:9c:3e:06:6f Sending Assoc Response to station on BSSID f4:7f:35:05:e6:10
*apfMsConnTask_6: Feb 12 13:27:20.881: dc:9b:9c:3e:06:6f Ignoring 802.11 assoc request from mobile pending deletion
*apfMsConnTask_6: Feb 12 13:27:20.881: dc:9b:9c:3e:06:6f Sending Assoc Response to station on BSSID f4:7f:35:05:e5:b0
*apfMsConnTask_5: Feb 12 13:27:20.905: dc:9b:9c:3e:06:6f Ignoring 802.11 assoc request from mobile pending deletion
*apfMsConnTask_5: Feb 12 13:27:20.905: dc:9b:9c:3e:06:6f Sending Assoc Response to station on BSSID f4:7f:35:05:e6:10
*apfMsConnTask_5: Feb 12 13:27:20.922: dc:9b:9c:3e:06:6f Ignoring 802.11 assoc request from mobile pending deletion
*apfMsConnTask_5: Feb 12 13:27:20.922: dc:9b:9c:3e:06:6f Sending Assoc Response to station on BSSID f4:7f:35:05:e6:10
*osapiBsnTimer: Feb 12 13:27:21.127: dc:9b:9c:3e:06:6f apfMsExpireCallback (apf_ms.c:589) Expiring Mobile!
*apfReceiveTask: Feb 12 13:27:21.128: dc:9b:9c:3e:06:6f apfMsExpireMobileStation (apf_ms.c:5584) Changing state for
mobile dc:9b:9c:3e:06:6f on AP f4:7f:35:05:e5:b0 from Associated to Disassociated
*apfReceiveTask: Feb 12 13:27:21.129: dc:9b:9c:3e:06:6f Sent Deauthenticate to mobile on BSSID f4:7f:35:05:e5:b0 slot
*apfReceiveTask: Feb 12 13:27:21.129: dc:9b:9c:3e:06:6f apfMsAssoStateDec
*apfReceiveTask: Feb 12 13:27:21.129: dc:9b:9c:3e:06:6f apfMsExpireMobileStation (apf_ms.c:5716) Changing state for
mobile dc:9b:9c:3e:06:6f on AP f4:7f:35:05:e5:b0 from Disassociated to Idle
*apfReceiveTask: Feb 12 13:27:21.129: dc:9b:9c:3e:06:6f pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE =
0.
*apfReceiveTask: Feb 12 13:27:21.129: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) Deleted mobile LWAPP rule on AP
[f4:7f:35:05:e5:b0]
*apfReceiveTask: Feb 12 13:27:21.129: dc:9b:9c:3e:06:6f apfMsRunStateDec
*apfReceiveTask: Feb 12 13:27:21.129: dc:9b:9c:3e:06:6f apfMs1xStateDec
*apfReceiveTask: Feb 12 13:27:21.129: dc:9b:9c:3e:06:6f Deleting mobile on AP f4:7f:35:05:e5:b0(1)
*pemReceiveTask: Feb 12 13:27:21.131: dc:9b:9c:3e:06:6f 172.16.9.163 Removed NPU entry.
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f Adding mobile on LWAPP AP f4:7f:35:05:e5:b0(1)
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f Association received from mobile on AP f4:7f:35:05:e5:b0
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f 0.0.0.0 START (0) Changing IPv4 ACL 'none' (ACL ID 255) ===>
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f 0.0.0.0 START (0) Changing IPv6 ACL 'none' (ACL ID 255) ===>
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f Applying site-specific Local Bridging override for station
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f Applying Local Bridging Interface Policy for station
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f processSsidIE statusCode is 0 and status is 0
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f processSsidIE ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f STA - rates (8): 140 18 152 36 176 72 96 108 0 0 0 0 0 0 0 0
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f suppRates statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f Processing RSN IE type 48, length 20 for mobile
dc:9b:9c:3e:06:6f
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f 0.0.0.0 START (0) Initializing policy
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f 0.0.0.0 START (0) Change state to AUTHCHECK (2) last state
AUTHCHECK (2)
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f 0.0.0.0 AUTHCHECK (2) Change state to 8021X_REQD (3) last
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f 0.0.0.0 8021X_REQD (3) DHCP Not required on AP
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f Not Using WMM Compliance code qosCap 00
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f 0.0.0.0 8021X_REQD (3) Plumbed mobile LWAPP rule on AP
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f apfMsAssoStateInc
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f apfPemAddUser2 (apf_policy.c:268) Changing state for mobile
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f Scheduling deletion of Mobile Station: (callerId: 49) in
1800 seconds
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f Sending Assoc Response to station on BSSID f4:7f:35:05:e5:b0
*apfMsConnTask_6: Feb 12 13:27:23.922: dc:9b:9c:3e:06:6f apfProcessAssocReq (apf_80211.c:6290) Changing state for
*dot1xMsgTask: Feb 12 13:27:23.926: dc:9b:9c:3e:06:6f Creating a PKC PMKID Cache entry for station dc:9b:9c:3e:06:6f
(RSN 2)
*dot1xMsgTask: Feb 12 13:27:23.926: dc:9b:9c:3e:06:6f Resetting MSCB PMK Cache Entry 0 for station dc:9b:9c:3e:06:6f
*dot1xMsgTask: Feb 12 13:27:23.926: dc:9b:9c:3e:06:6f Setting active key cache index 8 ---> 8
*dot1xMsgTask: Feb 12 13:27:23.926: dc:9b:9c:3e:06:6f Setting active key cache index 8 ---> 0
*dot1xMsgTask: Feb 12 13:27:23.926: dc:9b:9c:3e:06:6f Adding BSSID f4:7f:35:05:e5:bc to PMKID cache at index 0 for
*dot1xMsgTask: Feb 12 13:27:23.926: New PMKID: (16)
*dot1xMsgTask: Feb 12 13:27:23.926: [0000] df b2 42 72 6b d8 3f ab 9e 72 94 54 72 24 fd 3d
*dot1xMsgTask: Feb 12 13:27:23.927: dc:9b:9c:3e:06:6f Initiating RSN PSK to mobile dc:9b:9c:3e:06:6f
*dot1xMsgTask: Feb 12 13:27:23.927: dc:9b:9c:3e:06:6f dot1x - moving mobile dc:9b:9c:3e:06:6f into Force Auth state
*dot1xMsgTask: Feb 12 13:27:23.927: dc:9b:9c:3e:06:6f Skipping EAP-Success to mobile dc:9b:9c:3e:06:6f
*dot1xMsgTask: Feb 12 13:27:23.927: dc:9b:9c:3e:06:6f Found an cache entry for BSSID f4:7f:35:05:e5:bc in PMKID cache
*dot1xMsgTask: Feb 12 13:27:23.927: Including PMKID in M1 (16)
*dot1xMsgTask: Feb 12 13:27:23.927: [0000] df b2 42 72 6b d8 3f ab 9e 72 94 54 72 24 fd 3d
*dot1xMsgTask: Feb 12 13:27:23.927: dc:9b:9c:3e:06:6f Starting key exchange to mobile dc:9b:9c:3e:06:6f, data packets
will be dropped
*dot1xMsgTask: Feb 12 13:27:23.927: dc:9b:9c:3e:06:6f Sending EAPOL-Key Message to mobile dc:9b:9c:3e:06:6f
state
*Dot1x_NW_MsgTask_7: Feb 12 13:27:23.934: dc:9b:9c:3e:06:6f Received EAPOL-Key from mobile dc:9b:9c:3e:06:6f
*Dot1x_NW_MsgTask_7: Feb 12 13:27:23.934: dc:9b:9c:3e:06:6f Received EAPOL-key in PTK_START state (message 2) from
*Dot1x_NW_MsgTask_7: Feb 12 13:27:23.934: dc:9b:9c:3e:06:6f Stopping retransmission timer for mobile dc:9b:9c:3e:06:6f
*Dot1x_NW_MsgTask_7: Feb 12 13:27:23.934: dc:9b:9c:3e:06:6f Sending EAPOL-Key Message to mobile dc:9b:9c:3e:06:6f
*Dot1x_NW_MsgTask_7: Feb 12 13:27:23.943: dc:9b:9c:3e:06:6f Received EAPOL-Key from mobile dc:9b:9c:3e:06:6f
*Dot1x_NW_MsgTask_7: Feb 12 13:27:23.943: dc:9b:9c:3e:06:6f Received EAPOL-key in PTKINITNEGOTIATING state (message 4)
*Dot1x_NW_MsgTask_7: Feb 12 13:27:23.943: dc:9b:9c:3e:06:6f apfMs1xStateInc
*Dot1x_NW_MsgTask_7: Feb 12 13:27:23.943: dc:9b:9c:3e:06:6f 0.0.0.0 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4)
*Dot1x_NW_MsgTask_7: Feb 12 13:27:23.943: dc:9b:9c:3e:06:6f 0.0.0.0 L2AUTHCOMPLETE (4) DHCP Not required on AP
*Dot1x_NW_MsgTask_7: Feb 12 13:27:23.943: dc:9b:9c:3e:06:6f Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_7: Feb 12 13:27:23.943: dc:9b:9c:3e:06:6f 0.0.0.0 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP
*Dot1x_NW_MsgTask_7: Feb 12 13:27:23.943: dc:9b:9c:3e:06:6f 0.0.0.0 L2AUTHCOMPLETE (4) Change state to DHCP_REQD (7)
*Dot1x_NW_MsgTask_7: Feb 12 13:27:23.943: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) pemAdvanceState2 5253, Adding TMP
rule
*Dot1x_NW_MsgTask_: Feb 12 13:27:23.943: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) Adding Fast Path rule
*Dot1x_NW_MsgTask_7: Feb 12 13:27:23.943: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) Fast Path rule (contd...) 802.1P =
*Dot1x_NW_MsgTask_7: Feb 12 13:27:23.943: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) Successfully plumbed mobile rule
*Dot1x_NW_MsgTask_7: Feb 12 13:27:23.943: dc:9b:9c:3e:06:6f Stopping retransmission timer for mobile dc:9b:9c:3e:06:6f
*pemReceiveTask: Feb 12 13:27:23.944: dc:9b:9c:3e:06:6f 0.0.0.0 Added NPU entry of type 9, dtlFlags 0x0
*pemReceiveTask: Feb 12 13:27:23.944: dc:9b:9c:3e:06:6f Sent an XID frame
*IPv6_Msg_Task: Feb 12 13:27:24.008: dc:9b:9c:3e:06:6f Pushing IPv6: fe80:0000:0000:0000: 1017:eb84:7c42:0b6a , and
*DHCP Socket Task: Feb 12 13:27:25.929: dc:9b:9c:3e:06:6f DHCP received op BOOTREQUEST (1) (len 308,vlan 5, port 1,
encap 0xec03)
*DHCP Socket Task: Feb 12 13:27:25.929: dc:9b:9c:3e:06:6f DHCP dropping packet due to ongoing mobility handshake
*apfReceiveTask: Feb 12 13:27:26.928: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) State Update from Mobility-Incomplete to
*apfReceiveTask: Feb 12 13:27:26.928: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) pemAdvanceState2 4891, Adding TMP rule
*apfReceiveTask: Feb 12 13:27:26.928: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) Replacing Fast Path rule
IPv4 ACL ID = 255,
*apfReceiveTask: Feb 12 13:27:26.928: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) Fast Path rule (contd...) 802.1P = 0,
*apfReceiveTask: Feb 12 13:27:26.928: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) Successfully plumbed mobile rule (IPv4
*apfReceiveTask: Feb 12 13:27:26.928: dc:9b:9c:3e:06:6f IPv6 client got an IPv6 addresses, continue the PEM process
*apfReceiveTask: Feb 12 13:27:26.928: dc:9b:9c:3e:06:6f apfMsRunStateInc
*apfReceiveTask: Feb 12 13:27:26.928: dc:9b:9c:3e:06:6f 0.0.0.0 DHCP_REQD (7) Change state to RUN (20) last state RUN
(20)
*apfReceiveTask: Feb 12 13:27:26.929: dc:9b:9c:3e:06:6f 0.0.0.0 RUN (20) Reached PLUMBFASTPATH: from line 5776
*apf: Feb 12 13:27:26.929: dc:9b:9c:3e:06:6f 0.0.0.0 RUN (20) Replacing Fast Path rule
*apfReceiveTask: Feb 12 13:27:26.929: dc:9b:9c:3e:06:6f 0.0.0.0 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP =
*apfReceiveTask: Feb 12 13:27:26.929: dc:9b:9c:3e:06:6f 0.0.0.0 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID
*pemReceiveTask: Feb 12 13:27:26.930: dc:9b:9c:3e:06:6f 0.0.0.0 Added NPU entry of type 9, dtlFlags 0x0
*pemReceiveTask: Feb 12 13:27:26.930: dc:9b:9c:3e:06:6f Sent an XID frame
*pemReceiveTask: Feb 12 13:27:26.930: dc:9b:9c:3e:06:6f 0.0.0.0 Added NPU entry of type 1, dtlFlags 0x0
*pemReceiveTask: Feb 12 13:27:26.930: dc:9b:9c:3e:06:6f Pushing IPv6: fe80:0000:0000:0000: 1017:eb84:7c42:0b6a , and
*pemReceiveTask: Feb 12 13:27:26.931: dc:9b:9c:3e:06:6f 0.0.0.0, VLAN Id 9 Not sending gratuitous ARP
*DHCP Socket Task: Feb 12 13:27:28.649: dc:9b:9c:3e:06:6f DHCP received op BOOTREQUEST (1) (len 308,vlan 5, port 1,
encap 0xec03)
*DHCP Socket Task: Feb 12 13:27:28.649: dc:9b:9c:3e:06:6f DHCP processing DHCP REQUEST (3)
*DHCP Socket Task: Feb 12 13:27:28.649: dc:9b:9c:3e:06:6f DHCP op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Feb 12 13:27:28.649: dc:9b:9c:3e:06:6f DHCP xid: 0x3b5d3075 (995962997), secs: 5, flags: 0
*DHCP Socket Task: Feb 12 13:27:28.649: dc:9b:9c:3e:06:6f DHCP chaddr: dc:9b:9c:3e:06:6f
*DHCP Socket Task: Feb 12 13:27:28.649: dc:9b:9c:3e:06:6f DHCP ciaddr: 0.0.0.0, yiaddr: 0.0.0.0
*DHCP Socket Task: Feb 12 13:27:28.649: dc:9b:9c:3e:06:6f DHCP siaddr: 0.0.0.0, giaddr: 0.0.0.0
*DHCP Socket Task: Feb 12 13:27:28.649: dc:9b:9c:3e:06:6f DHCP requested ip: 172.16.9.163
*DHCP Socket Task: Feb 12 13:27:28.649: dc:9b:9c:3e:06:6f DHCP successfully bridged packet to DS
*DHCP Socket Task: Feb 12 13:27:28.651: dc:9b:9c:3e:06:6f DHCP received op BOOTREPLY (2) (len 308,vlan 9, port 1,
encap 0xec00)
*DHCP Socket Task: Feb 12 13:27:28.651: dc:9b:9c:3e:06:6f DHCP processing DHCP ACK (5)
*DHCP Socket Task: Feb 12 13:27:28.651: dc:9b:9c:3e:06:6f DHCP op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Feb 12 13:27:28.651: dc:9b:9c:3e:06:6f DHCP xid: 0x3b5d3075 (995962997), secs: 0, flags: 0
*DHCP Socket Task: Feb 12 13:27:28.651: dc:9b:9c:3e:06:6f DHCP chaddr: dc:9b:9c:3e:06:6f
*DHCP Socket Task: Feb 12 13:27:28.651: dc:9b:9c:3e:06:6f DHCP ciaddr: 0.0.0.0, yiaddr: 172.16.9.163
*DHCP Socket Task: Feb 12 13:27:28.651: dc:9b:9c:3e:06:6f DHCP siaddr: 0.0.0.0, giaddr: 0.0.0.0
*DHCP Socket Task: Feb 12 13:27:28.651: dc:9b:9c:3e:06:6f DHCP server id: 172.16.9.1 rcvd server id: 172.16.9.1
*DHCP Socket Task: Feb 12 13:27:28.651: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) DHCP Address Re-established
*DHCP Socket Task: Feb 12 13:27:28.651: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) Reached PLUMBFASTPATH: from line 6091
*DHCP Soc: Feb 12 13:27:28.651: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) Replacing Fast Path rule
*DHCP Socket Task: Feb 12 13:27:28.651: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) Fast Path rule (contd...) 802.1P = 0,
*DHCP Socket Task: Feb 12 13:27:28.651: dc:9b:9c:3e:06:6f 172.16.9.163 RUN (20) Successfully plumbed mobile rule (IPv4
*DHCP Socket Task: Feb 12 13:27:28.651: dc:9b:9c:3e:06:6f Assigning Address 172.16.9.163 to mobile
*DHCP Socket Task: Feb 12 13:27:28.651: dc:9b:9c:3e:06:6f DHCP success event for client. Clearing dhcp failure count
*DHCP Socket Task: Feb 12 13:27:28.651: dc:9b:9c:3e:06:6f DHCP successfully bridged packet to STA
*pemReceiveTask: Feb 12 13:27:28.653: dc:9b:9c:3e:06:6f 172.16.9.163 Added NPU entry of type 1, dtlFlags 0x0
*pemReceiveTask: Feb 12 13:27:28.653: dc:9b:9c:3e:06:6f Pushing IPv6: fe80:0000:0000:0000: 1017:eb84:7c42:0b6a , and
02-12-2014 11:19 AM
Show WLAN summary
Then look at the WLAN ID of the SSID
show WLAN 3 for example
02-12-2014 11:38 AM
Here you are Scott! Thank you!
(Cisco Controller) >show wlan 2
WLAN Identifier.................................. 2
Profile Name..................................... TresWIN
Network Name (SSID).............................. TresWIN
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Radius-NAC State............................... Disabled
SNMP-NAC State................................. Disabled
Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 0
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ treswin
--More-- or (q)uit
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
--More-- or (q)uit
Authentication................................ Global Servers
Accounting.................................... Global Servers
Interim Update............................. Disabled
Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
802.11 Authentication:........................ Open System
Static WEP Keys............................... Disabled
802.1X........................................ Disabled
Wi-Fi Protected Access (WPA/WPA2)............. Enabled
WPA (SSN IE)............................... Disabled
WPA2 (RSN IE).............................. Enabled
TKIP Cipher............................. Enabled
AES Cipher.............................. Disabled
Auth Key Management
802.1x.................................. Disabled
PSK..................................... Enabled
CCKM.................................... Disabled
FT(802.11r)............................. Disabled
FT-PSK(802.11r)......................... Disabled
FT Reassociation Timeout................... 20
FT Over-The-Air mode....................... Enabled
--More-- or (q)uit
FT Over-The-Ds mode........................ Enabled
GTK Randomization.......................... Disabled
SKC Cache Support.......................... Disabled
CCKM TSF Tolerance......................... 1000
Wi-Fi Direct policy configured................ Disabled
EAP-Passthrough............................... Disabled
CKIP ......................................... Disabled
Web Based Authentication...................... Disabled
Web-Passthrough............................... Disabled
Conditional Web Redirect...................... Disabled
Splash-Page Web Redirect...................... Disabled
Auto Anchor................................... Disabled
FlexConnect Local Switching................... Disabled
FlexConnect Local Authentication.............. Disabled
FlexConnect Learn IP Address.................. Enabled
Client MFP.................................... Optional
Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Band Select...................................... Disabled
--More-- or (q)uit
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID IP Address Status
802.11u........................................ Disabled
Access Network type............................ Not configured
Network Authentication type.................... Not configured
Internet service............................... Disabled
HESSID......................................... 00:00:00:00:00:00
Hotspot 2.0.................................... Disabled
WAN Metrics configuration
Link status.................................. 0
Link symmetry................................ 0
Downlink speed............................... 0
Uplink speed................................. 0
Mobility Services Advertisement Protocol....... Disabled
--More-- or (q)uit
(Cisco Controller)
02-13-2014 06:18 AM
Hi Scott!! I hope you're doing great!
Could you find something? or have any suggestion ?
Thanks in adnvance!
Regards.
02-13-2014 07:21 AM
This is wrong:
When using WPA2, you need to use AES not TKIP.
Scott
02-13-2014 07:24 AM
So back to the basics... here is something to remember:
WPA1/TKIP = WPA-Personal or WPA-Enterprise
WPA2/AES - WPA2-Personal or WPA2-Enterprise
This is how the standards are built. Some manufactures don't follow the standard tightly and thus you can mix and match. When a manufacture follows a standard strictly, well, you can't mix and match. It's also best to just configure one or the other and not both at the same time.
Scott
02-14-2014 07:37 AM
Hey Scott! I hope you're doing great!
I changed it to AES has you told me. But, the another network that has this same parameters has no problem to connect to these devices. A idk what else to do, it's kind of weird that i can connect to one network without a problem but no to this one. And i made a show wlan lan with the one that has no problems, and the values of the output were the same.
Do you have any other suggestion?
Thanks in advance Scott.
Regards.
02-14-2014 07:32 PM
Are you using an OEAP?
02-14-2014 08:46 PM
The one thing that you need to also do is to delete the SSID from the device. On the iPad and iPhones you need to forget the network and add the SSID again. The original will not work anymore. Give that a try.
02-17-2014 04:02 PM
We noticed something really weird.
We need to "forget this network" on the devices in order to connect to the new WLAN.
We are thinking that this might be a bug.
So i think we're going to do an upgrade to the WLC.
I'll tell what happenned.
Thanks everybody for your suggestions and time!!
Best Regards!
02-18-2014 07:54 AM
It's not a bug on the WLC... if you change anything on the SSID, you need to "forget this network" on the devices in order to connect to the SSID again.
Scott
