Community Helping Community
97
Problem with 3850 stack switch and wireless services
Strange issue, not sure if anybody has seen this before.
A new pair of 3850's in a stack.
IOS XE 3.3.3SE, IP Services.
AP's on switch 1and2 register ok.
AP's on switch 1 advertise WLANs and service clients.
AP's on switch 2 advertise WLANs but do not service clients.
Checking the license right-to-use usage, only slot1(switch1) seems to have AP licences!
Any guidance appreciated and rated!
Everyone's tags (1)
2 REPLIES 2
check your WLC config and
check your WLC config and look for VLAN tagging. may be you are tagging the data plane and not un tagging it on switch. also check on configuring the interface mode.
best wishes,
Mohit
Highlighted
Thanks Mohit, could you
Thanks Mohit, could you explain in a config?
These AP's are connected to a pair of stacked 3850's, and are all in the same access vlan.
Regards, Ash.
Content for Community-Ad
August's Community Spotlight Awards
