1108
Beginner
Problem With AIR-AP2802I-C-K9
I am facing problem with AIR-AP2802I-C-K9 that the client get very low speed. We are using WLC 2504 with 8.3 OS version. We use country code US and PK. We also use AIR-CAP1702I-D-K9 and this has no issue. I also check the country code for  AIR-AP2802I-C-K9 but we did not get the country code for -C region.
Please advise us the solution.
Thanking you-
Azizur Rahman
10 REPLIES 10
VIP Mentor
First check if both radios(802.11a & 802.11b) are up for this AP or not!
Second, paste the output of this commnd: sh wlan <id> from wlc!
Dont forget to rate helpful posts
Beginner
Please find the below output:
(Cisco Controller) >show wlan 1
WLAN Identifier.................................. 1
Profile Name..................................... Berger
Network Name (SSID).............................. BergerCorporate
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Client Profiling Status
Radius Profiling ............................ Disabled
DHCP ....................................... Disabled
HTTP ....................................... Disabled
Local Profiling ............................. Enabled
DHCP ....................................... Enabled
HTTP ....................................... Enabled
Radius-NAC State............................... Disabled
SNMP-NAC State................................. Disabled
Quarantine VLAN................................ 0
Maximum Clients Allowed.......................... Unlimited
Maximum number of Clients per AP Radio........... 200
--More-- or (q)uit
ATF Policy....................................... 0
Number of Active Clients......................... 70
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
User Idle Timeout................................ Disabled
Sleep Client..................................... disable
Sleep Client Timeout............................. 720 minutes
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... none
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ vlan22
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Tunnel Profile................................... Unconfigured
Quality of Service............................... Silver
--More-- or (q)uit
Per-SSID Rate Limits............................. Upstream Downstream
Average Data Rate................................ 0 0
Average Realtime Data Rate....................... 0 0
Burst Data Rate.................................. 0 0
Burst Realtime Data Rate......................... 0 0
Per-Client Rate Limits........................... Upstream Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... 802.1P (Tag=0)
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
--More-- or (q)uit
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
Authentication................................ 192.168.10.30 1812 *
Accounting.................................... Global Servers
Interim Update............................. Disabled
Interim Update Interval.................... 0
Framed IPv6 Acct AVP ...................... Prefix
Dynamic Interface............................. Disabled
Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Enabled (Profile 'bergerbd')
Radius NAI-Realm................................. Disabled
Mu-Mimo.......................................... Enabled
Security
802.11 Authentication:........................ Open System
FT Support.................................... Disabled
Static WEP Keys............................... Disabled
802.1X........................................ Disabled
Wi-Fi Protected Access (WPA/WPA2)............. Enabled
WPA (SSN IE)............................... Disabled
WPA2 (RSN IE).............................. Enabled
TKIP Cipher............................. Disabled
--More-- or (q)uit
AES Cipher.............................. Enabled
CCMP256 Cipher.......................... Disabled
GCMP128 Cipher.......................... Disabled
GCMP256 Cipher.......................... Disabled
OSEN IE.................................... Disabled
Auth Key Management
802.1x.................................. Enabled
PSK..................................... Disabled
CCKM.................................... Disabled
FT-1X(802.11r).......................... Disabled
FT-PSK(802.11r)......................... Disabled
PMF-1X(802.11w)......................... Disabled
PMF-PSK(802.11w)........................ Disabled
OSEN-1X................................. Disabled
SUITEB-1X............................... Disabled
SUITEB192-1X............................ Disabled
FT Reassociation Timeout................... 20
FT Over-The-DS mode........................ Enabled
GTK Randomization.......................... Disabled
SKC Cache Support.......................... Disabled
CCKM TSF Tolerance......................... 1000
Wi-Fi Direct policy configured................ Disabled
EAP-Passthrough............................... Disabled
--More-- or (q)uit
CKIP ......................................... Disabled
Web Based Authentication...................... Disabled
Web Authentication Timeout.................... 300
Web-Passthrough............................... Disabled
Mac-auth-server............................... 0.0.0.0
Web-portal-server............................. 0.0.0.0
Conditional Web Redirect...................... Disabled
Splash-Page Web Redirect...................... Disabled
Auto Anchor................................... Disabled
FlexConnect Local Switching................... Disabled
FlexConnect Central Association............... Disabled
flexconnect Central Dhcp Flag................. Disabled
flexconnect nat-pat Flag...................... Disabled
flexconnect Dns Override Flag................. Disabled
flexconnect PPPoE pass-through................ Disabled
flexconnect local-switching IP-source-guar.... Disabled
FlexConnect Vlan based Central Switching ..... Disabled
FlexConnect Local Authentication.............. Disabled
FlexConnect Learn IP Address.................. Enabled
Client MFP.................................... Optional
PMF........................................... Disabled
PMF Association Comeback Time................. 1
PMF SA Query RetryTimeout..................... 200
--More-- or (q)uit
Tkip MIC Countermeasure Hold-down Timer....... 60
Eap-params.................................... Disabled
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Split Tunnel Configuration
Split Tunnel................................. Disabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Enabled
802.11k Neighbor List Dual Band.................. Disabled
802.11v Directed Multicast Service............... Enabled
802.11v BSS Max Idle Service..................... Enabled
802.11v BSS Transition Service................... Enabled
802.11v BSS Transition Disassoc Imminent......... Disabled
802.11v BSS Transition Disassoc Timer............ 200
802.11v BSS Transition OpRoam Disassoc Timer..... 40
DMS DB is empty
Band Select...................................... Disabled
--More-- or (q)uit
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Universal Ap Admin............................... Disabled
Broadcast Tagging................................ Disabled
Mobility Anchor List
WLAN ID IP Address Status Priority
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Local Policy
Priority Policy Name
QoS Fastlane Status.............................. Disable
(Cisco Controller) >show wlan 2
WLAN Identifier.................................. 2
Profile Name..................................... Guest
Network Name (SSID).............................. BergerGuest
Local Profiling ............................. Disabled
--More-- or (q)uit
Number of Active Clients......................... 4
Session Timeout.................................. 86400 seconds
Interface........................................ vlan26
--More-- or (q)uit
--More-- or (q)uit
Radius Servers
Authentication................................ Disabled
Accounting.................................... Disabled
Local EAP Authentication......................... Disabled
Security
Wi-Fi Protected Access (WPA/WPA2)............. Disabled
Web Based Authentication...................... Enabled
IPv4 ACL........................................ Unconfigured
--More-- or (q)uit
IPv6 ACL........................................ Unconfigured
Web-Auth Flex ACL............................... Unconfigured
Web Authentication server precedence:
1............................................... local
2............................................... radius
3............................................... ldap
Client MFP.................................... Optional but inactive (WPA2 not configured)
--More-- or (q)uit
Eap-params.................................... Not Applicable
--More-- or (q)uit
DMS DB is empty
Local Policy
(Cisco Controller) >show wlan 3
WLAN Identifier.................................. 3
Profile Name..................................... Corporate
Network Name (SSID).............................. Corporate
--More-- or (q)uit
Number of Active Clients......................... 1
--More-- or (q)uit
--More-- or (q)uit
Radius Servers
Security
FT Support.................................... Adaptive
--More-- or (q)uit
Auth Key Management
802.1x.................................. Disabled
PSK..................................... Enabled
FT Over-The-DS mode........................ Disabled
--More-- or (q)uit
--More-- or (q)uit
DMS DB is empty
--More-- or (q)uit
Local Policy
VIP Advocate
Is your client using Windows
Is your client using Windows 10 creators update (build 1703)? If yes, there is a known issue in Windows, which is fixed in the Windows 10 build 15063.447.
This is KB4022716.
If you run any other version of Windows, you might need an updated driver for the Wi-Fi card. If it's an Intel 802.11ac card, get at least Intel Wireless Driver Pack 19.60.
Beginner
Thanks for your reply.
When my PC is connected with 1702I AP, then I got 12MBps but when my PC is connected with 2802I AP, then I got max 5 MBps.
Here I would like to mention you that we are using 2960x-24PDL to connect the APs.
Please advise.
Thanking You-
Azizur Rahman
Highlighted
VIP Advocate
Just to be sure, 12 MegaBytes
Just to be sure, 12 MegaBytes per second, right?
12 MB/s is still a bit on the low side with the 1702i, but much better than the 5 MB/s.
When you're connected tot he 2802i, what connection speed does your client show?  It should be something like 54, 144, 173, 300, 450, 600, 866 Mbps.
Beginner
Dear Patoberil,
Dear Patoberil,
When PC is connected to the 2802i, the client shows 5MB Max.
Thanking You-
Azizur Rahman
VIP Advocate
And what wireless connection
And what wireless connection speed is it showing?
Here a manual for Windows 10: http://winaero.com/blog/see-the-ethernet-or-wifi-adapter-speed-in-windows-10/
Beginner
Dear Patoberli,
Dear Patoberli,
It is 144 Mbps.
Thanking You-
Azizur Rahman
VIP Advocate
That means you are probably
That means you are probably running a 20 MHz channel on the 5 GHz or you're connected to the 2.4 GHz band.
Do you have AP Groups configured?
Can you check the configuration of the AP and the check what channel configuration is set?
Also make sure, if you use DFS, to have the country selected and all allowed channels.
Beginner
Re: That means you are probably
Old thread revived? Was this ever resolved as I have the same issue. Pulling my hair out at this one.
Have old 3602i on desk within 1m
Have new 2802i on desk within 1m
Both AP configured with Do0 2.4 20mhz and Do1 5ghz 40mhz/80mhz
Both AP connected to same switch with same configuration. Even tried swapping ports to isolate but symptoms followed.
5ghz works fine as expected on both AP
Connecting pc and mobile to 3602i 2.4ghz and connect rate around 200mbit on both devices as expected.
Connecting pc and mobile to 2802i 2.4ghz and connect rate is 5mbit on both devices. However, initial connection shows 130mbit before dropping to 5mbit. Traffic throughput confirms ~5mbit download and >1mbit up.
Both AP Do0 2.4ghz radios show same configuration for data rates 1-54, m0-23 etc.
The 2802i is running Mobility Express 8.8.100.0, but older firmware has been tried but symptoms remain.
Clearly this is an issue with the 2802i firmware or configuration, but is there a way to resolve this?
Content for Community-Ad
August's Community Spotlight Awards
