02-02-2017 07:15 AM - edited 07-05-2021 06:29 AM
Please I really need to know how to do the donwgrade from MSE CMX 10.x to MSE 8.x. I have 2 UCS 3365 and one is on CMX 10.2.3 and I need to downgrade to MSE 8.0.140 to use within HA, I tryed to find .iso file but there isn´t only 10.x .iso file are provide on cisco.com.
If some one have a guide to donwgrade from 10.x to 8.x please help me.
02-20-2017 10:24 AM
Chrystiano,
Please refer to the release notes for information about downgrading from 10.x to 8.x
Release Notes for Cisco Connected Mobile Experiences (CMX), Release 10.1 - Cisco
In addition, I recommend you check out the Cisco Support Community for more information and feedback about this issue.
https://supportforums.cisco.com/
I hope this help,
Kelli Glass
Moderator for Cisco Customer Communities
02-26-2017 07:58 PM
I already download CISCO-MSE-L-K9-8-0-110-10-64bit-MSE-3365-only.iso from Cisco. I follow the step-by-step from MSE configuration guide but after I selected ISO image the recovery process not begins. Please advise
02-27-2017 02:45 PM
Nanda,
If you continue to experience problems, then I recommend you open a case with Cisco Technical Support to investigate your particular set up - and to rule out a bug or other known issue.
Cisco Support - Software Downloads, Product Documentation, Support Tools, and Support Cases - Cisco
Kelli
03-05-2017 05:08 PM
Hi Chrystiano,
Are you still experiencing the issue?
I have been beta testing CMX 10.X for quite some time. I have asked the question around downgrading CMX 10.3 to 10.2 to both the BU and TAC before and I have been told there is no method to downgrade .x versions currently.
Unfortunately you will have to follow the procedure to install from OVA as per a new install. From what I can see you should be able to downgrade 10.x to 8.x but you need that OVA.
The 8.X OVA for VM Ware is currently available here: Cisco Systems not sure if this will help since your running the MSE 3365
cheers
Haydn
