164
Highlighted
Beginner
Problems with 2602i AP not joining WLC
Hi!
I am having a problem where my AP wont join the WLC.
I have solved this problem before by telling the access point where the AP is located. But i cannot remember how the command was.. Anyone have any idea?
/Lajja
1 ACCEPTED SOLUTION
Hall of Fame Master
Re: Problems with 2602i AP not joining WLC
the command is capwap ap controller IP address
-Scott
5 REPLIES 5
Hall of Fame Master
-Scott
Beginner
Thank you!
Hall of Fame Master
Make sure the time is set properly on the WLC and the country code for the AP is defined in the WLC. You can also place the ap on the same subnet as the WLC manager and have the ap join the WLC. Then after it joins you can move it to another vlan.
-Scott
Hall of Fame Master
Another command is: test capwap controller IP
-Scott
Content for Community-Ad
August's Community Spotlight Awards
