Problems with 2602i AP not joining WLC
Lajja1234
Hi!
I am having a problem where my AP wont join the WLC.
I have solved this problem before by telling the access point where the AP is located. But i cannot remember how the command was.. Anyone have any idea?
/Lajja
Scott Fella
the command is capwap ap controller IP address
-Scott
5 Replies 5
Scott Fella
-Scott
Thank you!
Scott Fella
Make sure the time is set properly on the WLC and the country code for the AP is defined in the WLC. You can also place the ap on the same subnet as the WLC manager and have the ap join the WLC. Then after it joins you can move it to another vlan.
-Scott
Scott Fella
Another command is: test capwap controller IP
-Scott
Abha Jha
