PSK SSID - Unable to connect
lazuardinurfaiz
I am using Cisco Wireless Controller 3504 running 8.10.112.0. I use this WLC for two site, both of them running flexconnect mode. On 1 site, I have a SSID using PSK as security. Recently, some endpoint (android smartphone) cannot connect to that SSID.
Can you help me to solve this issue?
Thank you.
Best regards,
Finally a solution to see the light at the end of the tunnel:
https://community.cisco.com/t5/wireless-and-mobility/issues-connecting-android-10-to-cisco-me/m-p/4096960#M116570
-Jesus
*** Please Rate Helpful Responses ***
9 Replies 9
Sandeep Choudhary
can you paste the output of these command:
sh wlan <id>
debug clinet <mac address>
Dont forget to rate helpful posts
Hi Sandeep.
I attached the output of show_wlan_id. I try to debug_client with the affected mac address, but no log is shown.
Best regards,
Lazuardi Nurfaiz
configuration looks all right. Please try the solution mentioned by Jesus Pavon and let us know.
There is another workaround to disable SHA1 and only use WPA2-SHA256 with FT disabled.
Can you share the device models affected by the issue? It all appears to be an issue related to latest Qualcomm chipsets' firmware with Cisco's IE att 44.
-Jesus
So far the affected by this issue is Android Smartphone using Android firmware version 10.
-Jesus
Thank you! After enabling FT on WLAN, all android 10 are able to connect.
JPavonM
Are those unable-to-connect devices using Android 10?
If so, please check this thread:
https://community.cisco.com/t5/wireless-and-mobility/issues-connecting-android-10-to-cisco-me/td-p/4009289
-Jesus
Hi Jesus.
Yes, exactly. All of the affected devices use Android 10. Thank you for the link. I will try to use solution in that link.
Best regards,
