I have a guest SSID with CWA configured on a C9800 with AP9115AX and i want to override all DSCP Values to 0 for all packets to and from the wifi clients.
i have tried a lot of configurations and a can drop traffic or shape traffic based on ACL or DSCP but not override DSCP Values vor example from DSCP 46 to 0.
Isn't this possible with 9800 Controllers ?
tried this straight forward configuration that i bind to my guest SSID but without success. maybe someone have a idea what to add or remove to the configuration . Maybe i missed some global config to enable ?
WLC9K#sh policy-map
Policy Map QOS-Override
Class QOS-Override1_ADV_UI_CLASS
set dscp default
Class class-default
set dscp default
WLC9K#show class-map QOS-Override1_ADV_UI_CLASS
Class Map match-all QOS-Override1_ADV_UI_CLASS (id 20)
Description: QOS-Override1_ADV_UI_CLASS UI_policy_DO_NOT_CHANGE
Match access-group name permit-any
WLC9K#sh access-lists permit-any
Extended IP access list permit-any
10 permit ip any any
65 deny ip any any
