05-29-2017 07:03 AM - edited 07-05-2021 07:07 AM
I am following instructions from this link http://www.cisco.com/c/en/us/td/docs/wireless/controller/8-3/config-guide/b_cg83/b_cg83_chapter_0100010.html#d14882e792a1635 to configure QoS per user or SSID
The problem is that I can only see what you can find attached; I have no option to configure any kind of data rate under QoS profiles or under WLAN configurations.
I have disabled 802.11a and 802.11b/g networks so that you can configure the QoS profiles. But still no option for data rates.
Any help would be appreciated,
Thanks and regards,
Joao Carvalho
Solved! Go to Solution.
05-29-2017 03:24 PM
2504 controller do NOT support Bandwidth Contract.
05-30-2017 01:52 AM
with the latest software version(8.0 or higher)..yes it is supported.
Dont forget to rate helpful posts
05-29-2017 03:24 PM
05-30-2017 01:42 AM
Hello Leo,
Do you know if vWLC support Bandwidth Contract?
05-30-2017 01:52 AM
