Community Helping Community
496
Beginner
Question About Authentication And Encryption
If I understand correctly
WPA2 has two parts
Authentication and encryption
If I use WPA2 enterprise with RADIUS server and certificates
The authentication part would take place within an encrypted (TLS or other) session
And data session will be encrypted with say AES.
Questions
  • •1. Is the above correct?
  • •2. Is the whole session between wireless device and AP encrypted and unhackable?
  • •3. When using WPA2 personal (PSK), is the session also encrypted with AES?
Everyone's tags (4)
2 ACCEPTED SOLUTIONS
Highlighted
Jacob,
Great questions! Always nice to see people deep dive this subject. I like you had all those questions as well.
Yes, Yes and Yes..
There are 2 very distinct authentications 802.1X and PSK. Both are part of the 802.11-2007 Standard. If you use radius <802.1X> a EAP type is used for authentication. Each EAP type has its own way of authenticating. Some are a dual authentication like PEAP, while others are not like LEAP.
PEAP for example uses MSCHAP V2 and TLS to send the login in a secure manner. Again, picking on LEAP uses MSCHAPV2 only, which is breakable and less secure.
After authentication. Then encryption is negoisated during the 4 WAY handshake. ONLY EAPs thats have dual authentication can do AES and TKIP due to the need for dyamic seeding material.
I blogged about a lot of this at my site
http://www.my80211.com/8021x/
Hope this helps
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Re: Question About Authentication And Encryption
Jacob
No worries
The 2 part hack is to get the key. At that point you can't see the traffic.
After you have a valid key and you capture a users authentication you could in theory see that users traffic. Your sniffer would have to allow you to decrypt the packets captured. I've never tried it personally with psk. I have with wep.
As for the cert I've never heard anyone actually breaking wireless in that manner. Not to say it can't happen. But that could take forever to do. You might have a better chance hitting the lottery.
9 REPLIES 9
Highlighted
Jacob,
Yes, Yes and Yes..
Hope this helps
Beginner
Just to clarify
a plain old home user laptop session on a home wirless router with WPA2 PSK setup, is encrypted for whole length of session?
no option of wireshark or anything to sniff around?
Correct. And each time you logon you will create new seeding material as well . You dont get the same KEY each time.
Beginner
thanks
with  WPA2 PSK how is the authentication part encrypted?
Good question ..
The PSK authentication is open to a hack if you capture 2 parts of the 4 way handshake. But this will not expose your traffic, rather it will expose your PSK key. Look up cow-patty hack.
As for the key encryption. During this process KEK,KCK keys are used to protect the keying process.
Read this ..
http://www.my80211.com/8021x/2010/10/3/george-stefanick-cwsp-journey-chapter-5-4-way-handshake-post.html
Beginner
Ur the King
No worries. I hope this helps. Stop back if you have issues.
Beginner
George
Sorry for opening this thread again
above you state
"The PSK authentication is open to a hack if you capture 2 parts of the 4 way handshake. But this will not expose your traffic, rather it will expose your PSK key. Look up cow-patty hack."
here:
http://serverfault.com/questions/149888/wep-wpa-wpa2-and-wifi-sniffing
i understand that if my PSK or CERT is compromised , the traffic encryption is very much in danger.
(also authorized users who know the PSK can sniff other users packets)
Jacob
No worries
Content for Community-Ad
August's Community Spotlight Awards
