07-23-2019 01:59 AM - edited 07-05-2021 10:44 AM
Hey all,
I would like to ask you something about a wifi design and it would be nice to get some helpful explanations.
There is a wlc in our headquarter. Additionally, in our branch offices are AP's that connect to the wlc in the HQ.
There is a wifi ssid that has Flex Connect enabled under "Advanced" tab. Futhermore, it uses dot1x for authentication.
Under "general" tab there is an interface configured that exists in the HQ.
My question is: When users in a BO connect to that wifi, how do they come into the local vlan there? Who manages that? How does the AP know?
Thank you!
07-23-2019 02:05 AM - edited 07-23-2019 02:08 AM
Its because flexconnect local swicthing is configured on WLAN.
Check this doc for more info:
Dont forget to rate helpful posts
07-23-2019 02:26 AM
Thank you!
What about the new wlc 9800 and AP 9120, do they still support Flexconnect?
07-23-2019 04:59 AM
yes the 9800s and the 9100 APs support flexconnect
07-24-2019 04:51 AM
