Radio problem on an AP1142N
I 've got a problem on an AP1142N. It joins correctly its controller (5508 WLC) but one of his radio (Dot11Radio1) won't go up :
#show cdp interface
Dot11Radio1 is reset, line protocol is down
  Encapsulation ARPA
  Sending CDP packets every 60 seconds
  Holdtime is 180 seconds
Here's what I have in my log file :
*Oct 19 11:13:20.536: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio1, Timed out waiting for fw to clear txp_pndg flag
*Oct 19 11:13:21.036: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio1, Timed out waiting for fw to clear txp_pndg flag
Is it an hardware problem?
Eric
*Mar  1 00:00:09.233: %SOAP_FIPS-2-SELF_TEST_RAD_FAILURE: RADIO crypto FIPS self test failed at 128 bit AMAC AES encrypt for TX on interface Dot11Radio 1 -Process= "Init", ipl= 0, pid= 3
RMA the WAP.  The radio module is faulty.
8 Replies 8
Damon Garner
Do you see anything in the log that mentions crash or traceback?
You may need to look at the previous log messages by typing this:
more flash:events.log
Can you also post the output for:
show ver
Leo Laohoo
Can you please post the complete output to the following commands:
1.  WLC:  sh sysinfo;
2.  WAP:  sh version; and
3.  WAP:  sh inventory
I don't see anything special in the event.log file. This WAP is a new one (first time that it's connected on my network).
1.  WLC:  sh sysinfo;
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.98.214
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... N/A
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
System Name...................................... AIR-ILM-WLC-C5-01
System Location.................................. Etage-5_Bt-C
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
IP Address....................................... 10.226.232.130
Last Reset....................................... Software reset
System Up Time................................... 245 days 12 hrs 30 mins 23 secs
System Timezone Location.........................
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
Next Boot License Type........................... Permanent
Configured Country............................... FR  - France
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +44 C
External Temperature............................. +23 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 6
Number of Active Clients......................... 305
Burned-in MAC Address............................ 54:75:D0:DE:D0:C0
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 100
2.  WAP:  sh version
Cisco IOS Software, C1140 Software (C1140-K9W8-M), Experimental Version 12.4(20110214:185845) [BLD-wnbu_j_esc1.201102141046 161]
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Mon 14-Feb-11 11:39 by
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA, RELEASE SOFTWARE (fc3)
AIR-ILM-AP-A7-04 uptime is 4 days, 4 hours, 1 minute
System returned to ROM by watchdog timer expired
System image file is "flash:/c1140-k9w8-mx.wnbu_j_esc1.201102141046/c1140-k9w8-mx.wnb"
cisco AIR-LAP1142N-E-K9    (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FCZ1316W04X
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from watchdog timer expired
LWAPP image version 7.0.98.214
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:22:90:91:2B:58
Part Number                          : 73-11451-05
PCA Assembly Number                  : 800-30554-02
PCA Revision Number                  : A0
PCB Serial Number                    : FOC13111JG2
Top Assembly Part Number             : 800-31273-01
Top Assembly Serial Number           : FCZ1316W04X
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1142N-E-K9
Configuration register is 0xF
NAME: "AP1140", DESCR: "Cisco Aironet 1140 Series (IEEE 802.11n) Access Point"
PID: AIR-LAP1142N-E-K9 , VID: V01, SN: FCZ1316W04X
upgrade the firmware of the controller to the newer 7.3.X.
Saravanan Lakshmanan
how the ap is powered.
what happens if tried to toggle ap and radio admin status from gui.
console into ap, bounce the ap, check the boot process for d1 radio initialization.
display - show cont d1, show log, more event.log.
It's powered by the switch (PoE).
show log :
Log Buffer (1048576 bytes):
*Mar  1 00:00:07.294: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:07.305: *** CRASH_LOG = YES
Security Core found.
Base Ethernet MAC address: 00:22:90:91:2B:58
*Mar  1 00:00:08.669: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:09.233: %SOAP_FIPS-2-SELF_TEST_RAD_FAILURE: RADIO crypto FIPS self test failed at 128 bit AMAC AEC CCM encrypt on interface Dot11Radio 1 -Process= "Init", ipl= 0, pid= 3
*Mar  1 00:00:09.234: %SOAP_FIPS-2-SELF_TEST_RAD_FAILURE: RADIO crypto FIPS self test failed at 128 bit AMAC AEC CCM decrypt on interface Dot11Radio 1 -Process= "Init", ipl= 0, pid= 3
*Mar  1 00:00:09.271: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 134 messages)
*Mar  1 00:00:09.291:  status of voice_diag_test from WLC is false
*Mar  1 00:00:10.331: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:11.409: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:11.452: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:11.452: %SNMP-5-COLDSTART: SNMP agent on host AIR-ILM-AP-A7-04 is undergoing a cold start
*Mar  1 00:00:11.524: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:11.524: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:12.524: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:00:12.524: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:00:21.521: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar  1 00:00:21.522: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:00:22.074: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio0, Timed out waiting for fw to clear txp_pndg flag
*Mar  1 00:00:22.574: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio1, Timed out waiting for fw to clear txp_pndg flag
*Mar  1 00:00:22.775: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:30.357:  status of voice_diag_test from WLC is false
*Mar  1 00:00:30.395: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:34.965: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:00:34.987: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:35.972: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:00:35.973: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
*Mar  1 00:00:49.426: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
more flash:event.log
*Mar 1 00:00:30.133: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C4506-E (e05f.b91a.9dd1)
*Mar 1 00:00:38.324: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar 1 00:00:38.326: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar 1 00:00:38.327: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER
*Oct 19 08:21:57.000: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Oct 19 08:21:57.001: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.226.232.130 peer_port: 5246
*Oct 19 08:21:58.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Oct 19 08:21:58.829: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.226.232.130 peer_port: 5246
*Oct 19 08:21:58.829: %CAPWAP-5-SENDJOIN: sending Join Request to 10.226.232.130
*Oct 19 08:21:58.829: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Oct 19 08:21:58.837: %CAPWAP-5-CHANGED: CAPWAP changed state to IMAGE
*Oct 19 08:22:38.812: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C4506-E (e05f.b91a.9dd1)
*Oct 19 08:22:39.976: *** Access point reloading. Reason: NEW IMAGE DOWNLOAD ***
*Mar 1 00:00:32.363: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar 1 00:00:32.373: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:00:33.359: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar 1 00:00:41.434: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar 1 00:00:41.436: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Oct 19 08:24:19.000: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Oct 19 08:24:19.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.226.232.130 peer_port: 5246
*Oct 19 08:24:20.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Oct 19 08:24:20.832: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.226.232.130 peer_port: 5246
*Oct 19 08:24:20.832: %CAPWAP-5-SENDJOIN: sending Join Request to 10.226.232.130
*Oct 19 08:24:20.832: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Oct 19 08:24:20.930: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Oct 19 08:24:21.047: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Oct 19 08:24:21.054: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct 19 08:24:21.539: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio1, Timed out waiting for fw to clear txp_pndg flag
*Oct 19 08:24:22.203: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio1, Timed out waiting for fw to clear txp_pndg flag
*Oct 19 08:24:22.212: %CAPWAP-5-CHANGED: CAPWAP changed state to UP
*Oct 19 08:24:22.222: %LWAPP-3-CLIENTEVENTLOG: Received AP Syslog IP Address(255.255.255.255) configuration.
*Oct 19 08:24:22.222: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller AIR-ILM-WLC-C5-01
*Oct 19 08:24:22.224: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Oct 19 08:24:22.224: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Oct 19 08:24:22.224: %LWAPP-3-CLIENTEVENTLOG: SSID XS4OFFICE added to the slot[0]
*Oct 19 08:24:22.224: %LWAPP-3-CLIENTEVENTLOG: SSID Guest-ILM added to the slot[0]
*Oct 19 08:24:22.224: %LWAPP-3-CLIENTEVENTLOG: SSID XS4MOBILITY added to the slot[0]
*Oct 19 08:24:22.224: %LWAPP-3-CLIENTEVENTLOG: SSID XS4OFFICE added to the slot[1]
*Oct 19 08:24:22.224: %LWAPP-3-CLIENTEVENTLOG: SSID XS4OfficePhone added to the slot[1]
*Oct 19 08:24:22.224: %LWAPP-3-CLIENTEVENTLOG: SSID XS4MOBILITY added to the slot[1]
*Oct 19 08:24:22.232: %DOT11-4-NO_HT: Interface Dot11Radio0, Mcs rates disabled on vlan 4 due to WMM is not enabled
*Oct 19 08:24:22.232: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct 19 08:24:23.231: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Oct 19 08:34:37.372: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Oct 19 08:34:37.479: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct 19 08:37:45.159: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.226.232.130:5246
*Oct 19 08:37:53.742: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Oct 19 08:37:53.746: %CAPWAP-3-ERRORLOG: Dropping dtls packet since session is not established.
*Oct 19 08:37:53.749: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Oct 19 08:37:53.757: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Oct 19 08:37:53.761: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Oct 19 08:37:53.764: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Oct 19 08:37:53.764: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Oct 19 08:37:53.771: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct 19 08:37:54.271: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio1, Timed out waiting for fw to clear txp_pndg flag
*Oct 19 08:37:54.279: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Oct 19 08:37:54.286: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Oct 19 08:37:54.286: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Oct 19 08:37:54.286: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Oct 19 08:37:54.294: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct 19 08:37:54.000: %CAPWAP-3-ERRORLOG: Selected MWAR 'AIR-ILM-WLC-C5-01'(index 0).
*Oct 19 08:37:54.001: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Oct 19 08:37:54.001: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.226.232.130 peer_port: 5246
*Oct 19 08:37:54.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Oct 19 08:37:54.835: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.226.232.130 peer_port: 5246
*Oct 19 08:37:54.835: %CAPWAP-5-SENDJOIN: sending Join Request to 10.226.232.130
*Oct 19 08:37:54.835: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Oct 19 08:37:54.944: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Oct 19 08:37:54.945: %LWAPP-3-CLIENTERRORLOG: spamSendDeleteMobile : AP is not UP state.
*Oct 19 08:37:54.946: %LWAPP-3-CLIENTERRORLOG: spamSendDeleteMobile : AP is not UP state.
*Oct 19 08:37:55.066: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Oct 19 08:37:55.074: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct 19 08:37:55.554: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio1, Timed out waiting for fw to clear txp_pndg flag
*Oct 19 08:37:56.130: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio1, Timed out waiting for fw to clear txp_pndg flag
*Oct 19 08:37:56.139: %CAPWAP-5-CHANGED: CAPWAP changed state to UP
*Oct 19 08:37:56.144: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller AIR-ILM-WLC-C5-01
*Oct 19 08:37:56.157: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Oct 19 08:37:56.157: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Oct 19 08:37:56.157: %LWAPP-3-CLIENTEVENTLOG: SSID XS4OFFICE added to the slot[0]
*Oct 19 08:37:56.157: %LWAPP-3-CLIENTEVENTLOG: SSID Guest-ILM added to the slot[0]
*Oct 19 08:37:56.157: %LWAPP-3-CLIENTEVENTLOG: SSID XS4MOBILITY added to the slot[0]
*Oct 19 08:37:56.158: %LWAPP-3-CLIENTEVENTLOG: SSID XS4OFFICE added to the slot[1]
*Oct 19 08:37:56.158: %LWAPP-3-CLIENTEVENTLOG: SSID XS4OfficePhone added to the slot[1]
*Oct 19 08:37:56.158: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct 19 08:37:56.159: %LWAPP-3-CLIENTEVENTLOG: SSID XS4MOBILITY added to the slot[1]
*Oct 19 08:37:57.155: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Oct 19 08:38:02.879: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio1, Timed out waiting for fw to clear txp_pndg flag
*Oct 19 08:43:31.787: %CAPWAP-5-CHANGED: CAPWAP changed state to DOWN
*Oct 19 08:43:31.824: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Oct 19 08:43:31.858: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Oct 19 08:43:31.859: %LWAPP-3-CLIENTEVENTLOG: SSID XS4OFFICE added to the slot[0]
*Oct 19 08:43:31.862: %LWAPP-3-CLIENTEVENTLOG: SSID XS4OFFICE added to the slot[1]
*Oct 19 08:43:31.862: %LWAPP-3-CLIENTEVENTLOG: SSID XS4OfficePhone added to the slot[1]
*Oct 19 08:43:31.864: %LWAPP-3-CLIENTEVENTLOG: SSID Guest-ILM added to the slot[0]
*Oct 19 08:43:31.866: %DOT11-4-NO_HT: Interface Dot11Radio0, Mcs rates disabled on vlan 3 due to WMM is not enabled
*Oct 19 08:43:31.912: %LWAPP-3-CLIENTEVENTLOG: SSID XS4MOBILITY added to the slot[0]
*Oct 19 08:43:31.916: %LWAPP-3-CLIENTEVENTLOG: SSID XS4MOBILITY added to the slot[1]
*Oct 19 08:43:31.919: %CAPWAP-5-CHANGED: CAPWAP changed state to UP
*Oct 19 08:43:31.920: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Oct 19 08:43:31.920: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Oct 19 08:43:31.928: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct 19 08:43:42.034: *** Access point reloading. Reason: Recvd RESET req from Controller ***
*Mar 1 00:00:34.669: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar 1 00:00:34.679: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:00:35.665: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Oct 19 11:13:19.001: %CAPWAP-3-ERRORLOG: Selected MWAR 'AIR-ILM-WLC-C5-01'(index 0).
*Oct 19 11:13:19.001: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Oct 19 11:13:19.001: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.226.232.130 peer_port: 5246
*Oct 19 11:13:19.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Oct 19 11:13:19.836: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.226.232.130 peer_port: 5246
*Oct 19 11:13:19.836: %CAPWAP-5-SENDJOIN: sending Join Request to 10.226.232.130
*Oct 19 11:13:19.836: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Oct 19 11:13:19.922: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Oct 19 11:13:20.045: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Oct 19 11:13:20.052: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct 19 11:13:20.537: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio1, Timed out waiting for fw to clear txp_pndg flag
*Oct 19 11:13:21.119: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio1, Timed out waiting for fw to clear txp_pndg flag
*Oct 19 11:13:21.128: %CAPWAP-5-CHANGED: CAPWAP changed state to UP
*Oct 19 11:13:21.139: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller AIR-ILM-WLC-C5-01
*Oct 19 11:13:21.140: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Oct 19 11:13:21.141: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Oct 19 11:13:21.141: %LWAPP-3-CLIENTEVENTLOG: SSID XS4OFFICE added to the slot[0]
*Oct 19 11:13:21.141: %LWAPP-3-CLIENTEVENTLOG: SSID Guest-ILM added to the slot[0]
*Oct 19 11:13:21.141: %LWAPP-3-CLIENTEVENTLOG: SSID XS4MOBILITY added to the slot[0]
*Oct 19 11:13:21.141: %LWAPP-3-CLIENTEVENTLOG: SSID XS4OFFICE added to the slot[1]
*Oct 19 11:13:21.141: %LWAPP-3-CLIENTEVENTLOG: SSID XS4OfficePhone added to the slot[1]
*Oct 19 11:13:21.142: %LWAPP-3-CLIENTEVENTLOG: SSID XS4MOBILITY added to the slot[1]
*Oct 19 11:13:21.149: %DOT11-4-NO_HT: Interface Dot11Radio0, Mcs rates disabled on vlan 3 due to WMM is not enabled
*Oct 19 11:13:21.152: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct 19 11:13:22.147: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Oct 24 12:43:02.288: *** Access point reloading. Reason: Reload Command ***
But there's something strange when I check the controller dot11radio 1 :
AIR-ILM-AP-A7-04#show controllers dot11Radio 1
Radio disabled 8
interface Dot11Radio1
Radio AIR-AP1140A, Base Address 0025.4542.bda0, BBlock version 0.00, Software version 3.00.75
Serial number: FOC131303M9
Number of supported simultaneous BSSID on Dot11Radio1: 16
Carrier Set: ETSI (OFDM) (EU) (-E)
Uniform Spreading Required: Yes
Configured Frequency: 0 MHz  Channel 0
Allowed Frequencies: 5180(36) 5200(40) 5220(44) 5240(48) 5260(52) 5280(56) 5300(60) 5320(64) 5500(100) 5520(104) 5540(108) 5560(112) 5580(116) 5660(132) 5680(136) 5700(140)
Listen Frequencies: 5170(34) 5180(36) 5200(40) 5220(44) 5240(48) 5260(52) 5280(56) 5300(60) 5320(64) 5500(100) 5520(104) 5540(108) 5560(112) 5580(116) 5600(120) 5620(124) 5640(128) 5660(132) 5680(136) 5700(140) 5745(149) 5765(153) 5785(157) 5805(161) 5825(165)
Beacon Flags: 0, Interface Flags 60109, Interface Events 0, Mode 9; Beacons are disabled; Probes are disabled
Configured Power: 17 dBm (level 1)
Ok thx for your answer.
