09-09-2019 10:53 AM - edited 07-05-2021 10:58 AM
Hi, I'm reaching out to see if anyone has encountered this issue.
IOS Bootloader - Starting system.
flash is writable
40MB format
Cyprus MB -- 40MB of flash
Xmodem file system is available.
flashfs[0]: 24 files, 5 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 13406208
flashfs[0]: Bytes available: 27752448
flashfs[0]: flashfs fsck took 10 seconds.
Base Ethernet MAC address: a4:6c:2a:48:65:a0
port 5 Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:/c1570-k9w8-mx.153-3.JD14/c1570-k9w8-mx.153-3.JD14"...#############################################
File "flash:/c1570-k9w8-mx.153-3.JD14/c1570-k9w8-mx.153-3.JD14" uncompressed and installed, entry point: 0x1003000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C1570 Software (C1570-K9W8-M), Version 15.3(3)JD14, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Fri 23-Mar-18 15:40 by prod_rel_team
40MB format
Initializing flashfs...
flashfs[2]: 24 files, 5 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 40900608
flashfs[2]: Bytes used: 13406208
flashfs[2]: Bytes available: 27494400
flashfs[2]: flashfs fsck took 12 seconds.
flashfs[2]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 0 seconds.
flashfs[4]: Initialization complete.
Copying radio files from flash: to ram:
Copy in progress...CCC
Copy in progress...CCCCCCCCCCC
Uncompressing radio files...
...done Initializing flashfs.
create idb =66E0218
vtu index 1 is created
vtu index 2 is created
vtu index 3 is created
vtu index 4 is created
vtu index 5 is created
eth_wait stop the ios now, need be changed to 0
Radio0 not present 0 0 0 0 0 0
Radio1 not present 0 0 0 0 0 4
No radios initialized!
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1572EAC-A-K9 (PowerPC) processor (revision C0) with 376814K/134656K bytes of memory.
Processor board ID FGL1917Y04U
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.3.141.0
5 Gigabit Ethernet interfaces
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address:
Part Number :
PCB Serial Number :
Top Assembly Part Number :
Top Assembly Serial Number :
Top Revision Number :
Product/Model Number : AIR-AP1572EAC-A-K9
% Please define a domain-name first.
fake phy int done idb =
Press RETURN to get started!
*Mar 1 00:00:15.847: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (15)
*Mar 1 00:00:16.187: Registering HW DTLS
*Mar 1 00:00:16.195: Non-Cable-Modem AP present
*Mar 1 00:00:17.059: idb 0 =9AEB1D4
*Mar 1 00:00:17.059: idb 1 =9AECC78
*Mar 1 00:00:17.059: idb 2 =9AEE86C
*Mar 1 00:00:17.059: idb 3 =9AF0460
*Mar 1 00:00:17.059: idb 4 =9AF2054
APAVC Registering AVC licences on the AP to make sure we enable advanced PP
*Mar 1 00:00:18.287: %LINK-6-UPDOWN: Interface Ethernet0, changed state to up
*Mar 1 00:00:18.447: Starting Ethernet promiscuous modeAPAVC Protocol list already initialized.
*Mar 1 00:00:18.715: Start STILE Activation
APAVC: Succeeded to activate all the STILE protocols.
APAVC: Registering with CFT
*Mar 1 00:00:18.963: APAVC: CFT registration of delete callback succeeded
APAVC: Reattaching Original Buffer pool for system use
*Mar 1 00:00:19.199: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:19.199: %LINK-6-UPDOWN: Interface GigabitEthernet1, changed state to up
*Mar 1 00:00:19.199: %LINK-6-UPDOWN: Interface GigabitEthernet2, changed state to up
*Mar 1 00:00:19.199: %LINK-6-UPDOWN: Interface GigabitEthernet3, changed state to up
*Mar 1 00:00:19.199: %LINK-6-UPDOWN: Interface GigabitEthernet4, changed state to up
*Mar 1 00:00:20.603: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar 1 00:00:20.603: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1, changed state to down
*Mar 1 00:00:20.603: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2, changed state to down
*Mar 1 00:00:20.603: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet3, changed state to down
*Mar 1 00:00:20.603: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4, changed state to down
*Mar 1 00:00:21.591: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:21.591: %SNMP-5-COLDSTART: SNMP agent on host APa46c.2a48.65a0 is undergoing a cold startAstools: Could not initialize functionality
*Mar 1 00:00:22.907: The AVR image is up-to-date (1.0.0.31)
*Mar 1 00:00:22.911: change led intensity to 100 percent
*Mar 1 00:00:22.911: AVR module accelerometer initialized
*Mar 1 00:00:22.951: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power source
*Mar 1 00:00:23.151: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:24.867: %LWAPP-3-CLIENTERRORLOG: bsnSetCurrentBHRate : fail to set radio control and data rate
lwapp_crypto_init: MIC Present and Parsed Successfully
*Mar 1 00:00:25.027: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:00:29.399: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (2-16)
*Mar 1 00:00:29.399: DPAA Initialization Complete
*Mar 1 00:00:29.399: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar 1 00:00:31.623: get_radio_temp input parameter wrong 0 radioidb =0x0
*Mar 1 00:00:31.623: get_radio_temp input parameter wrong 1 radioidb =0x0
*Mar 1 00:00:34.099: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar 1 00:00:35.099: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
*Mar 1 00:00:37.059: %DOT11-3-ADD_PRIM_IDB_TOLIST: can not add idb GigabitEthernet0 to the private list
*Mar 1 00:00:39.991: Currently running a Release Image
*Mar 1 00:00:40.015: Using SHA-2 signed certificate for image signing validation.
*Mar 1 00:00:40.103: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:41.059: %LINK-6-UPDOWN: Interface BVI1, changed state to up
*Mar 1 00:00:41.643: Orientation: Changed to Horizontal
*Mar 1 00:00:42.059: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar 1 00:00:45.967: AP image integrity check PASSED
*Mar 1 00:00:45.971: Non-recovery image. PNP Not required.
*Mar 1 00:00:45.983: Cert ISSUER (39): cn=Cisco Manufacturing CA SHA2,o=Cisco
*Mar 1 00:00:45.999: %MESH-6-ADJACENCY_STATE_MACHINE_STARTED: Mesh adjacency state machine started
Not in Bound state.
*Mar 1 00:00:51.587: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.0.8.12, mask 255.255.255.0, hostname APa46c.2a48.65a0
%Error opening flash:/capwap-saved-config (No such file or directory)
%Error opening flash:/capwap-saved-config-bak (No such file or directory)
*Mar 1 00:00:56.015: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 0 CLI Request Triggered
*Mar 1 00:00:56.019: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar 1 00:00:57.015: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 514 started - CLI initiated
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (8.8.8.8)
*Mar 1 00:01:02.127: %LWAPP-3-CLIENTERRORLOG: bsnSetCurrentBHRate : fail to set radio control and data rate
*Mar 1 00:01:13.215: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
*Sep 9 14:57:11.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.0.8.1 peer_port: 5246
*Sep 9 14:57:12.399: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.0.8.1 peer_port: 5246
*Sep 9 14:57:12.399: %CAPWAP-5-SENDJOIN: sending Join Request to 10.0.8.1
*Sep 9 14:57:12.407: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.0.8.1:5246
*Sep 9 14:57:12.407: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
*Sep 9 14:57:12.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.0.8.1 peer_port: 5246
*Sep 9 14:57:21.999: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
*Sep 9 14:57:22.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.0.8.1 peer_port: 5246
*Sep 9 14:57:22.000: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:224 Connection 0xC9B9A98 is already there for this server port 5246, Deleting it. Number of connections: 1
*Sep 9 14:57:22.000: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.0.8.1:5246
Also, what are all these zeros, and why there is a 4 at the end of Radio1?
Thank you for helping me out
09-09-2019 02:06 PM
Not in Bound state.
It seems this AP came with mesh image. Therefore you have to add AP ethernet MAC address under (Security -> AP Policies -> Add -> 1572 Ethernet Mac Address [cert type MIC] -> click Add)
Then AP should get registered and then you can change it from Bridge mode to local & you can roleback above configuration.
If AP Radio issue persisting, I would suggest to upgrade WLC code to 8.5.151.0 & test it again (it is most likely a software bug)
Rasika
*** Pls rate all useful responses ***
09-10-2019 07:37 AM
I tried to upload the new firmware (8.5.151.0) but for some reason it says: LWAPP image version 8.3.141.0
How would you upload the firmware? maybe I am doing something wrong
Thank you
09-10-2019 11:45 AM
First you need to register AP to WLC with current version.
Then you need to upgrade your WLC 8.5.151.0
Rasika
09-11-2019 06:53 AM
Figured out that the network card inside the AP is burned.
