ā08-18-2013 09:55 PM - edited ā07-04-2021 12:40 AM
Hi ,
Can anyone please help me to have updated vendorMacs.xml for PI 1.3. ?
I may have to quickly update it .Please provide me the URL if you have.
Thanks& Regards,
Senthil
ā08-19-2013 01:35 PM
As per your query i can suggest you the following solution-
Hope this will help you.
ā08-20-2013 03:09 AM
Prime Infrastructure relies on the IEEE Organizational Unique Identifier (OUI) database to identify the client vendor name mapping. Prime Infrastructure stores vendor OUI mappings in an XML file named vendorMacs.xml. This file is updated for each release of Prime Infrastructure. With the OUI update, you can perform the following:
ā¢Change the vendor display name for an existing OUI.
ā¢Add new OUIs to Prime Infrastructure.
ā¢Refresh the vendorMacs.xml file with new vendor OUI mappings and upload it to Prime Infrastructure.
This section contains the following topics:
ā¢Adding a New Vendor OUI Mapping, page 15-1169
ā¢Uploading an Updated Vendor OUI Mapping File, page 15-1170
ā08-22-2013 11:56 PM
I have updated the VendorMacs.xml and uploaded it.It is availble with bit less number of entries in other websites.
Thanks much Ravi.
ā01-18-2021 11:13 PM
This is a popular question on google and old as well.
So I thought it is better to reply to whoever is looking for the same.
This link contains the updated vendorMacs.xml file for PI infrastructure.
The update frequency is daily, so it should have all the entries up to date.
