07-29-2013 02:56 PM - edited 07-04-2021 12:32 AM
Hello
how to reset to factory default the WLC 5500, admin password is not working too
thanks
Vishal
07-29-2013 03:19 PM
Hello Vishael
If you can use GUI for admin password, you can console to WLC 5508. When WLC is booting press scape key and try with recovery password
07-29-2013 03:20 PM
You can use this link
http://www.cisco.com/en/US/products/ps6308/products_password_recovery09186a008071faa7.shtml
07-29-2013 06:22 PM
Once controller boot up & prompted for username type "recover-config". That will do what you want.
https://supportforums.cisco.com/docs/DOC-1639
Rasika
07-30-2013 03:03 PM
As per your query i can suggest you the following link-
Hope this will help you.
