07-06-2010 12:02 AM - edited 07-03-2021 06:56 PM
Dear All,
We have an AIR-LAP1142N-E-K9 deployed in a H-REAP setup.
This AP already got the configuration from the WLC when it was deployed at a remote site.
Now we moved it to another site, but it doesn't appear in the WCS and i don't see any CAPWAP debug messages on the WLC.
The routing work fine between the AP and the WLC, the AP also gets an IP address from DHCP and also received Option 43 information.
Now my guess was that the AP doesn't associate with the WLC because it has the old config file and it runs in local mode(without trying to connect to the WLC).
We want to reset to factory defaults because we want to delete the configuration and force the AP to get a new config from the WCS.
I don't know the enable password so i had to use other methods for reseting to factory defaults.
I tried to use the information from here:
I used the "MODE button":
I get the following message from the console:
"button pressed for 5 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
Solved! Go to Solution.
03-05-2018 06:24 AM
Thanks!! This little piece of info helped me out a great deal.
10-16-2018 12:43 PM
12-10-2010 04:37 PM
Just found an autonomous IOS 1240 with a valid config and I rebooted the AP to run the "rcv" file. Because it previously had a statically-assigned IP address, the IP address remained and I couldn't log in because I did not clear the config before the "rcv" boot.
What I did to fix this is to load the autonomous IOS using the "mode button", cleared the config and copied the "rcv" file back.
10-10-2012 08:24 AM
Hi all,
I have also the same problem,
private-multiple-fs file is deleted on flash. But it's be genereated automaticaly when AP is startup.
I have all tryed that have been described above. Help plz. Ik have to do to default factory
APc471.fe6d.c6dc#sh flash:
Directory of flash:/
2 -rwx 76 Mar 1 2002 00:04:19 +00:00 private-multiple-fs
3 -rwx 95973 Mar 1 2002 00:20:49 +00:00 event.log
4 -rwx 0 Mar 1 2002 00:04:19 +00:00 env_vars
34 drwx 384 May 13 2011 14:22:20 +00:00 c1140-k9w8-mx.124-23c.JA
7 drwx 128 Mar 1 2002 00:12:13 +00:00 c1140-rcvk9w8-mx
32385024 bytes total (25297408 bytes free)
RELOAD
using eeprom values
WRDTR,CLKTR: 0x86000800 0x40000000
RQDC ,RFDC : 0x80000037 0x0000020b
ddr init done
IOS Bootloader - Starting system.
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x86000800, 0x40000000
RQDC, RFDC : 0x80000037, 0x0000020b
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is up.
PCIE1: VC0 is active
PCIEx: initialization done
flashfs[0]: 28 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 7093760
flashfs[0]: Bytes available: 25291264
flashfs[0]: flashfs fsck took 18 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: c4:71:fe:6d:c6:dc
Waiting for PHY auto negotiation to complete TIMEOUT !
done
Ethernet speed is 10 Mb - HALF duplex
The system has encountered an error initializing
the Ethernet port.
The system is ignoring the error and continuing to boot.
If you abort the system boot process, the following
commands will re-initialize Ethernet, TFTP, and finish
loading the operating system software:
ether_init
tftp_init
boot
Loading "flash:/c1140-k9w8-mx.124-23c.JA/c1140-k9w8-mx.124-23c.JA"...########### ################################################################################ ################################################################################ ############
File "flash:/c1140-k9w8-mx.124-23c.JA/c1140-k9w8-mx.124-23c.JA" uncompressed and installed, entry point: 0x4000
executing...
enet halted
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C1140 Software (C1140-K9W8-M), Version 12.4(23c)JA, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 01-Jun-10 12:29 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
FLASH CHIP: Numonyx P33
Checking for Over Erased blocks
flashfs[1]: 28 files, 8 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32126976
flashfs[1]: Bytes used: 7093760
flashfs[1]: Bytes available: 25033216
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete.
flashfs[2]: 0 files, 1 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 11999232
flashfs[2]: Bytes used: 1024
flashfs[2]: Bytes available: 11998208
flashfs[2]: flashfs fsck took 1 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
Waiting for PHY auto negotiation to complete... TIMEOUT !
Ethernet link is down.
Radio0 present 8363 8000 90020000 0 90030000 B
Radio1 present 8363 8000 98020000 0 98030000 0
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco AIR-LAP1142N-E-K9 (PowerPC405ex) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FCZ1447W2EA
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from power-on
LWAPP image version 7.0.98.0
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address:
Part Number :
PCA Assembly Number : 800-30554-06
PCA Revision Number : A0
PCB Serial Number :
Top Assembly Part Number : 800-31273-04
Top Assembly Serial Number :
Top Revision Number : A0
Product/Model Number : AIR-LAP1142N-E-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar 1 00:00:07.947: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar 1 00:00:07.958: *** CRASH_LOG = YES
Security Core found.
Base Ethernet MAC address: C4:71:FE:6D:C6:DC
*Mar 1 00:00:49.990: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar 1 00:00:49.991: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:50.557: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar 1 00:00:50.610: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1024 messages)
*Mar 1 00:00:50.630: status of voice_diag_test from WLC is false
*Mar 1 00:00:52.790: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:52.790: %SNMP-5-COLDSTART: SNMP agent on host APc471.fe6d.c6dc is undergoing a cold start
*Mar 1 00:00:52.839: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar 1 00:00:52.898: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar 1 00:00:52.898: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:00:52.898: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power source
*Mar 1 00:00:52.950: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:00:53.443: %DOT11-2-TX_PWR_TIMO: Interface Dot11Radio1, Timed out waiting for fw to clear txp_pndg flag
*Mar 1 00:00:53.648: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:00:53.752: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar 1 00:00:53.776: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:00:53.908: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar 1 00:00:53.908: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar 1 00:01:11.695: status of voice_diag_test from WLC is false
*Mar 1 00:01:11.733: Logging LWAPP message to 255.255.255.255.
*Mar 1 00:01:11.767: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar 1 00:01:11.788: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:01:11.788: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:01:11.796: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
*Mar 1 00:01:11.803: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:01:21.768: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
10-10-2012 09:33 AM
simple, delete everything on the Flash...start with new image..and you have DHCP 43, it should join automatically.
10-10-2012 12:35 PM
Hi Yahya,
Thanks for your answerd. That is my problem. Beacuse i cant download image.
I must first backup current image to tftp server.
but configure terminal not working.
If i am delete image, than i have bigger problem.
10-10-2012 10:16 PM
I would consider opening a TAC case, it will be solved in 10 minutes.
10-10-2012 11:55 PM
I do not have to access the TAC Service.
01-22-2013 05:03 PM
You can reset your Aironet 1142N to factory default by 2 methods
The first method is to remove the power (adapter or the ethernet adapter when the device get its power by PoE)
Press the mode button and reconnect the power. Hold the mode button for at least 2 seconds when its powering on.
The second method is by the CLI (Telnet or Console port) in enable mode execute the following commands
write erase
reload (and confirm)
01-22-2013 05:10 PM
write erase
If you use only "write erase", the static IP address remains.
If you want to delete everything, including IP address, you have to use the command "write default-config".
01-23-2013 10:47 AM
Your right
04-22-2013 12:50 PM
Hold the reset button down with the AP powered on. Then unplug the power form the Ap while continuing to hold the button down. Then plug the power back in, still holding the reset button. The lights will flash on the AP. When it is blue, release the rest button. Hope that helps.
01-08-2021 07:12 AM
Three easy steps to Reset Cisco AP using MODE button:
https://www.youtube.com/channel/UCmZZ2BNGXQH1HPS3uIVnr7A?sub_confirmation=1
Step 1: Disconnect power (the power jack for external power or the Ethernet cable for in-line power) from the access point.
Step 2: Press and hold the MODE button while you reconnect power to the access point.
Step 3: Hold the MODE button until the Status LED turns amber (approximately 10 to 12 seconds), and release the Button. All access point settings return to factory defaults.
