Highlighted
Beginner
Restricting WLANs on a specific LWAP
I've inherited an environment with the following:
1 x WLC 4402
20 x AIR-LAP1131AG-A-K9
2 WLANs
     Guest (wide open)
     Internal (802.1x + WPA2)
I'm new to the controller-based wireless environments.  My question is how do I restrict which WLANs are accessible from a particular AP when all the APs are homed to the same controller?
TIA.
1 ACCEPTED SOLUTION
Highlighted
What version of code is your WLC running?
Pre 5.2 you would would go into each radio and could enable override and select which WLAN that AP serviced.
Post 5.2 you configure AP groups.  In the AP group, you list all the WLAN you want serviced by particular AP's, then assign the AP's to the group.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
4 REPLIES 4
Highlighted
Steve
Highlighted
Beginner
Figured it out shortly after I posted the message.  It's configured at the radio level, not the AP level, which I should've realized.
Highlighted
Beginner
That's right. But incase you want a particular SSID to be broadcasted on a AP, then create a group and add that AP into that group and while adding you can define what ssid to be broadcasted in that group. Quite simple.
Highlighted
Stephen,
Make sure if you have a backup WLC, that you create the idenitial group on all other WLCs that your aps will attach to. If you do not. They will fall back into default, which means they will broadcast the first 16 on that WLC.
Also the groups are case and space sensitive.
If you create ap group one called > GROUP1 make sure your other WLCs use the same name > GROUP1.
Content for Community-Ad
