11-06-2012 12:44 PM - edited 07-03-2021 10:59 PM
Hi all,
I'm using WLC and WCS to manage lightweight access points.
Is it possible to retrieve/export from WLCs or WCS the full configuration of all APs in a simple way?
11-06-2012 12:55 PM
Why do you want to do that? The WAP doesn't have a permanent config. All config is stored and managed by the WLC.
11-07-2012 02:34 AM
Becouse my client i asking to provide the APs' documentation.
I'm thinking to provide the full WLC configuration (show run-conf).
There is a way to make " copy running-config tftp" in WLC ?
Or you suggest a better way?
11-07-2012 02:39 AM
Sure. In the GUI you can backup your config. Is this what you want to do?
Go to Commands > Upload Files.
In the File Type, choose Configuration from the drop-down menu.
11-07-2012 07:26 AM
Thanks for the reply.
Anyway i hae tried but this will provide only the WLC configuration.
What i'm looking for is the configuration of the APs....
11-07-2012 04:49 PM
The WLC configurations will include configs for the WAPs.
11-07-2012 10:29 PM
I have open the configuration of WLC obtained as follow:
1) WLC: Commands > Upload Files
2) WCS: Administration > Background Tasks > Controller Configuration Backup
And in both files there is no AP configuration...
11-08-2012 05:25 AM
The configurations come from the WLC not the AP. They might still have the mindset of autonomous access point. The bottom line is that the APs don't have a configuration... The WLC provides the configuration to an access point when it's joined. If you want to provide them with something, issue the following command from the WLC CLI:
show ap config general
