RSSI low even when really close to an accesspoint
Bartvdm
After a survey we placed 12 access points in our warehouse. 3802's with 4x AIR-ANT2535SDW-R dipole antenna's each. In the WLC (2504 wlc) antenna gain is set to 6x0,5dBi for each accesspoint.
We are using 2.4ghz only, 5ghz has been disabled (but when I enabled it I saw simular results)
I walked around in our warehouse checking the WLC client page and noticed that I never got a better RSSI then -60 dBi at best (8 meters from the accesspoint hanging on the ceiling) this is more or less the same for every accesspoint.
I manually adjusted powerlevel for the 2.4ghz antenna's to 2 (it was 4,5 or 6 for all accesspoints), so I expected a huge increase of the RSSI, nope.. -55dBi at best from that 8 meter of those accesspoints.
I then got into a forklift and got close to 1 meter of that accesspoint (powerlevel still set to 2), RSSI went up to -45dBi, still far from what I expected. (I was expecting something in the area of -35 or even -30 when being so close to the AP)
any idea where this problem is coming from?
Thanks a million!
7 Replies 7
fdharmawan
Level 4
Level 4
Hi Bartvdm,
When you said "I manually adjusted powerlevel for the 2.4ghz antenna's to 2", did you mean the power is 2/7 (17dBm)?
Hi fdharmawan That is correct
Tx Power Num Of Supported Power Levels ............. 7
Tx Power Level 1 .......................... 18 dBm
Tx Power Level 2 .......................... 15 dBm
Tx Power Level 3 .......................... 12 dBm
Tx Power Level 4 .......................... 9 dBm
Tx Power Level 5 .......................... 6 dBm
Tx Power Level 6 .......................... 3 dBm
Tx Power Level 7 .......................... 2 dBm
Tx Power Configuration .................... MANUAL
Current Tx Power Level .................... 2
Hi Bart,
Any reason why did you raise the tx power level to such high level? If you complain about the RSSI around -60dBm, may I know what is wrong with that? I guess -60dBm falls on good-to-perfect signal. The WiFi signal meter is still full bar, right? Do you have any connectivity issue such as ping over 10ms or traffic performance?
If I were you, I would not set the power manually and let the RRM does the job. Besides, sometimes the greater the power might not equals to better WiFi signal.
And one more thing. RSSI is client stand point. The AP might 'see' your laptop but your laptop wireless NIC might not 'see' the AP.  I forgot the term in this but your laptop's wireless NIC have a range too.
patoberli
Why do you want such a strong signal strength in 8 meters distance?
Do you have coverage issues?
I've barely ever seen more than -40dbi, but I also haven't really measured that a lot of times.
because I did a survey, and the results where dramatic, coverage would not go below -60 is 95% of the warehouse
Jurgens L
Level 3
Level 3
When using the AIR-ANT2535SDW-R at 8meters you won't get the optimal performance out of it as it's not designed to be that high.
In warehouse environments where AP's normally need to be installed higher than 6m, directional antennas is a better option.
