Highlighted
Beginner
Rx Neighbors & Co-channel Infterference
Hi all,
With an 802.11G WLAN if my AP's can see 1 or more AP's on the same channel as itself within Rx Neighbours could this be a indication of co-channel interference? - Or would this only be the case if the RSSI of the Rx Neighbor on the same channel was above a certain level?
Neil
1 REPLY
Contributor
Re: Rx Neighbors & Co-channel Infterference
AP has a neighbor on same channel for 2.4 GHz radio, with power. These reports on possible co-channel interference. This may or may not be relevant depending on power and application used. AP has a neighbor on same channel for 5 GHz radio, with power. These reports on possible co-channel interference. This may or may not be relevant depending on power and application used. AP has a neighbor on an adjacent channel for X GHz radio, with power. This reports possible adjacent channel interference, which may be disruptive depending on how far is the AP on channel distance, and the power received
Ask the Expert- Webex Hybrid Services Solutions
