11-13-2012 02:10 AM - edited 07-03-2021 11:01 PM
A easy question
Can I set the same dynamic interface in 2 differents SSIDs?
Thank you.
Best Regars.
Solved! Go to Solution.
11-13-2012 05:29 AM
Yes you can. That was pretty easy:)
11-13-2012 05:29 AM
11-13-2012 07:31 AM
I agree with Scott.
+5 Scott :-)
11-13-2012 07:34 AM
Great!!
Thank you for the asnwers.
A costumer asked me about that and I wanted to be sure that is possible.
