02-25-2019 01:34 PM - edited 07-05-2021 09:56 AM
I am currently trying to configure an ISR 1111 Cellular Router. I have the config set up, and then went into the AP module so that I can connect it to my WLC that is set up for it.
I made a mistake in the initialization wizard I could not skip and I cannot find a way to change the AP mode from Static to DHCP. This is why I wish to reset the AP to its factory defaults so I can go through the wizard again.
I cannot find anything online that can assist, so any help is appreciated.
Solved! Go to Solution.
02-26-2019 05:57 AM
Unfortunately, it seems as though this model does not recognize wlan-ap0. I did find online:
router#hw-module subslot x/y error-recovery password_reset
It did allow me to get back into the initialization wizard.
02-25-2019 01:40 PM
You can try this:
service-module wlan-ap0 reset default-config
Let me know if that works.
02-26-2019 05:57 AM
