Popup Hotspot Using ISR 1000 with WiFi/LTE for Teleworkers and Micro Branchesr
Ask Me Anything – How to Enable Network Connectivity to Remote Workers
1444
Highlighted
Frequent Contributor
sh dot11 associations client command on 1811w
Hi all,
Wireless is working ok on 1811W.
Need to know from command output below what values are considered  good for power and signal strenghts
1811w#sh dot11 associations all-client
Address           : 40fc.894e.c48c     Name             : NONE
IP Address        : 192.168.98.2       Interface        : Dot11Radio0
Device            : unknown            Software Version : NONE
CCX Version       : NONE
State             : Assoc              Parent           : self
SSID              : ACDinternet        VLAN             : 98
Hops to Infra     : 1                  Association Id   : 5
Clients Associated: 0                  Repeaters associated: 0
Tunnel Address    : 0.0.0.0
Key Mgmt type     : WPA PSK            Encryption       : TKIP
Current Rate      : 54.0               Capability       : WMM ShortHdr ShortSlot
Supported Rates   : 1.0 2.0 5.5 11.0 18.0 24.0 36.0 54.0 6.0 9.0 12.0 48.0
Signal Strength   : -40  dBm           Connected for    : 12389 seconds
Signal Quality    : N/A                Activity Timeout : 56 seconds
Power-save        : On                 Last Activity    : 64 seconds ago
Packets Input     : 1745               Packets Output   : 1005
Bytes Input       : 223588             Bytes Output     : 901041
Duplicates Rcvd   : 8                  Data Retries     : 64
Decrypt Failed    : 0                  RTS Retries      : 0
MIC Failed        : 0                  MIC Missing      : 0
Packets Redirected: 0                  Redirect Filtered: 0
Address           : 74e5.0b5b.e788     Name             : 1811w
IP Address        : 192.168.98.3       Interface        : Dot11Radio0
Device            : 4500-radio         Software Version : NONE
CCX Version       : 4
Hops to Infra     : 1                  Association Id   : 12
Supported Rates   : 1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Signal Strength   : -48  dBm           Connected for    : 2354 seconds
Signal Quality    : N/A                Activity Timeout : 20 seconds
Power-save        : Off                Last Activity    : 0 seconds ago
Packets Input     : 6480               Packets Output   : 3345
Bytes Input       : 1299557            Bytes Output     : 3231413
Duplicates Rcvd   : 24                 Data Retries     : 206
Address           : a00b.bacf.37a5     Name             : NONE
IP Address        : 192.168.98.5       Interface        : Dot11Radio0
CCX Version       : NONE
Hops to Infra     : 1                  Association Id   : 11
Signal Strength   : -63  dBm           Connected for    : 2392 seconds
Signal Quality    : N/A                Activity Timeout : 50 seconds
Power-save        : On                 Last Activity    : 70 seconds ago
Packets Input     : 1764               Packets Output   : 1323
Bytes Input       : 347117             Bytes Output     : 1297921
Duplicates Rcvd   : 34                 Data Retries     : 425
Also what is Association ID  mean in above output?
Mahesh
Everyone's tags (6)
2 ACCEPTED SOLUTIONS
Highlighted
Hall of Fame Community Legend
A signal strength of up to -65 dBm is very, very good.  Up to -75 is good.  Anything else is useless.
Highlighted
Yes.  They are very, very good signal strength from the clients to the WAP.
Wireless is a two-way street.  You also have to verify what the signal strength is from each client to the WAP.
5 REPLIES 5
Highlighted
Highlighted
Hi Leolaohoo,
I have 2 devices with -40db and one with -63db so are they good?
Mahesh
Highlighted
Highlighted
Many thanks leolaohoo
Mahesh
Highlighted
Thanks for the ratings, Mahesh.
Content for Community-Ad
Cisco COVID-19 Survey
