09-17-2013 10:09 AM - edited 07-04-2021 12:51 AM
I want to know that what's the maximum range (distance) of Cisco ap 1130. How can I configure to increase the signal strength. 2.4 ghz or 5ghz is best to configure. Shall I extend the range by installing external antenna? Does 1130 support external antenna?
09-17-2013 10:13 AM
The answer to that is it varies. All depends on what is in the area of the AP, what power level and what data rates you have configured.
And the 1130 is internal antenna only, so you are not able to attach an external antenna.
What are you looking to do?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
09-17-2013 05:56 PM
1130 does not support external antenna. For more information do refer to the datasheet of 1130
09-17-2013 06:15 PM
Put it this way.... If your AP is at default and you only added the basic configuration and SSID's your running at the highest TX available data rates. You will not get any better than that.
09-17-2013 08:50 PM
Inorder to have better signal experience,
>>Replace devices in your place that can interfere with network traffic on the 2.4GHz frequency range or switch to 5Ghz operational frequency!
>>Check your router's signal strength with these devices. Compare power levels when each device is on and off to determine if they are the cause of your signal problems.
>>switch to different channels.
>>SWitch to 802.11n standard as it offers far greater range and signal strength compared to 802.11 a/b/g.
>>Reposition your AP and Antenna
>>Be aware of external interference.
>>Raise your transmit power ( configure the radio interface settings )
>>Replace the Antenna if needed, as sometimes due to faulty antenna, power loss is observed.
09-18-2013 12:01 AM
Thanks All,
how to configure power rate and data rate in ap?
how to change radio interface settings in this regard.
If i will configure the ap in 5ghz then strenght will be better?
09-18-2013 12:05 AM
Beginning in privileged EXEC mode, follow these steps to set the transmit power on access point radios:
Use the no form of the power command to return the power setting to maximum, the default setting.
You can also limit the power level on client devices that associate to the access point. When a client device associates to the access point, the access point sends the maximum power level setting to the client.
Beginning in privileged EXEC mode, follow these steps to specify a maximum allowed power setting on all client devices that associate to the access point:
09-18-2013 03:21 AM
hi,
I just want to know that whats the by default speed & power of radio interface.
wifi(config-if)# speed ?
1.0 Allow 1.0 Mb/s rate
11.0 Allow 11.0 Mb/s rate
12.0 Allow 12.0 Mb/s rate
18.0 Allow 18.0 Mb/s rate
2.0 Allow 2.0 Mb/s rate
24.0 Allow 24.0 Mb/s rate
36.0 Allow 36.0 Mb/s rate
48.0 Allow 48.0 Mb/s rate
5.5 Allow 5.5 Mb/s rate
54.0 Allow 54.0 Mb/s rate
6.0 Allow 6.0 Mb/s rate
9.0 Allow 9.0 Mb/s rate
basic-1.0 Require 1.0 Mb/s rate
basic-11.0 Require 11.0 Mb/s rate
basic-12.0 Require 12.0 Mb/s rate
basic-18.0 Require 18.0 Mb/s rate
basic-2.0 Require 2.0 Mb/s rate
basic-24.0 Require 24.0 Mb/s rate
basic-36.0 Require 36.0 Mb/s rate
basic-48.0 Require 48.0 Mb/s rate
basic-5.5 Require 5.5 Mb/s rate
basic-54.0 Require 54.0 Mb/s rate
basic-6.0 Require 6.0 Mb/s rate
basic-9.0 Require 9.0 Mb/s rate
default Set default rates
ofdm How to place OFDM rates in rates elements
only-ofdm Set rates for best OFDM throughput (no ERP protection will be
used)
range Set rates for best range
throughput Set rates for best throughput (includes non-OFDM rates and may
cause ERP protection to be used)
wifi(config-if)#power local ?
<-1 - 14> One of: -1 2 5 8 11 14
cck Set power for CCK rates
maximum Set power to allowed maximum
ofdm Set power for OFDM rates
09-18-2013 04:40 AM
Post your show run-config.
If you never changed the tx power or the data rates, then it should be at default which will give you the max coverage for that AP. For 2.4ghz the default mandatory basic rates are:
1,2,5.5,11
All the rest are just entered to be available
Here is a link
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_10b_JA/configuration/guide/scg12410b-chap6-radio.html#wp1232120
09-18-2013 05:55 AM
can i configure this ap with 5 ghz ?
09-18-2013 05:57 AM
Yes as long as you have a 5ghz radio. 5ghz doesn't go as far as the 2.4ghz, so that will not help with extending coverage.
09-18-2013 03:16 PM
Aqeel,
Please remove your post. Your response is taken out of a marketing document. We are talking about real-world scenario. So you need a more realistic cut-and-paste from a technical document.
