06-15-2016 11:25 PM - edited 07-05-2021 05:14 AM
My question is if I have a single SSID on an autonomous AP so do i have to use the native vlan too. I mean what is the best practice in this case if the wireless vlan is say 10.
Also do i have to use the bvi-1 or i have to creat another bvi for that vlan?
Solved! Go to Solution.
06-15-2016 11:31 PM
As per my experience...its not a must to use native vlan.
No you have to use only one BVI interface.
Just like this:
Conf ter
Dot11 ssid ABC
Vlan 10
Authentication open
Authentication key-management wpa version2
wpa-psk ascii cisco123
Guest-mode
ind d0
ssid ABC
encryption vlan 10 cipher aes
ind d1
ssid ABC
encryption vlan 20 cipher aes
ind d0.10
encapsulation dot1q 10
ind d1.10
ind gig0.10
int bvi1
ip address <ip><mask>
Dont forget to rate helpful posts
06-15-2016 11:56 PM
And if you want to use a mgmt vlan and other vlan is for client then your config must look like this:
Conf ter
Dot11 ssid ABC
Vlan 10
Authentication open
Guest-mode
ind d0
ssid ABC
ind d1
ssid ABC
ind d0.1
bridge-group 1
ind d1.1
bridge-group 1
ind gig0.1
bridge-group 1
ind d0.10
bridge-group 10
ind d1.10
bridge-group 10
ind gig0.10
bridge-group 10
int bvi1
Configuration from the Switch Side
conf t
int Gig 1/1
switchport mode trunk
switchport trunk native vlan 1
switchport trunk allowed vlan 1,2
06-15-2016 11:31 PM
Just like this:
Conf ter
Dot11 ssid ABC
Vlan 10
Authentication open
Guest-mode
ind d0
ssid ABC
ind d1
ssid ABC
ind d0.10
ind d1.10
ind gig0.10
int bvi1
06-15-2016 11:50 PM
Ok fine thanks alot bro.
03-28-2019 04:16 AM
Is Dot1Q a must even though the AP is in autonomous mode using a single ssid and the switchport is configured as access port only.
Ashish
06-15-2016 11:56 PM
Conf ter
Dot11 ssid ABC
Vlan 10
Authentication open
Guest-mode
ind d0
ssid ABC
ind d1
ssid ABC
ind d0.1
bridge-group 1
ind d1.1
bridge-group 1
ind gig0.1
bridge-group 1
ind d0.10
bridge-group 10
ind d1.10
bridge-group 10
ind gig0.10
bridge-group 10
int bvi1
conf t
int Gig 1/1
12-29-2020 11:15 PM
In the following video step by step process has been shown How to Configure Cisco AIRONET 3602i Autonomous/Standalone Access Point using CLI with WPAv2 Authentication Key.
https://www.youtube.com/channel/UCmZZ2BNGXQH1HPS3uIVnr7A?sub_confirmation=1
https://www.youtube.com/watch?v=JkUfTXuwj2U
============ For 2.4 GHz Radio Interface ============
Step 1: Access Cisco AP|Reset AP| Assign static IP for BVI1 Interface |Default-gateway IP
ap>enable
Password: Cisco [Cisco AP default Password]
## Reset the Access Point with pressing and holding mode button ##
ap#configure terminal
ap(config)#interface bvI 1
ap(config-if)#ip address 192.168.2.4 255.255.255.0 [According to my network setup]
ap(config-if)#exit
ap(config)#ip default-gateway 192.168.2.1 [According to my network setup]
Step 2: Creating SSID | Authentication | Applying WPAv2 Authentication
ap(config)#dot11 ssid Cisco_WLAN [ Create SSID named Cisco_WLAN]
ap(config-ssid)#guest-mode [Broadcast SSID]
ap(config-ssid)#authentication open [allows any device to authenticate]
ap(config-ssid)#authentication key-management wpa version 2 [Applying WPAv2 Authentication]
ap(config-ssid)#wpa-psk ascii Cisco123 [Applying WPA Shared Key ]
ap(config-ssid)#exit
Step 3: Enable Encryption to 4.2GHz Radio interface | Apply SSID to interface| Enable Radio Interface
ap(config)#interface dot11Radio 0 [Selecting 4.2 GHz Radio interface]
ap(config-if)#encryption mode ciphers aes-ccm [Enabling CIPHER AES-CCM Encryption to interface]
ap(config-if)#ssid Cisco_WLAN [Applying SSID to Radio interface]
ap(config-if)#channel least-congested [Selecting Channel type]
ap(config-if)#no shutdown [Finally Enabling the 4.2 GHz Radio Interface]
ap(config-if)#exit
ap(config)#exit
================ For 5 GHz Radio Interface =======================
ap(config)#dot11 ssid Cisco_WLAN 5GHz [ Create SSID named Cisco_WLAN 5GHz ]
Step 3: Enable Encryption to 5 GHz Radio interface | Apply SSID to interface| Enable Radio Interface
ap(config)#interface dot11Radio 1 [Selecting 5 GHz Radio interface]
ap(config-if)#ssid Cisco_WLAN 5GHz [Applying SSID to Radio interface]
ap(config-if)# channel 36 [Selecting Channel type]
ap(config-if)#no shutdown [Finally Enabling the 5 GHz Radio Interface]
ap(config-if)#exit
ap(config)#exit
