243
Beginner
Solution for point to multi point in cisco which should support min 10 kms
I have 289 locations where for every 5 to 10 locations i want to create a P2MP connectivity where the distance between 2 locations will be from 5 kms to 10 kms. Is there any solution in Cisco. If yes can you brief me on this.
2 REPLIES 2
VIP Advisor
Re: Solution for point to multi point in cisco which should support min 10 kms
What is the use case here ? You do not have Fibre / DWDM here ?
Personally  Microwave is quite expenssive if you want to deploy this kind of solution. (until there is no options available for you)
BB
*** Rate All Helpful Responses ***
Highlighted
Beginner
I appreciate this is a Cisco forum, but if you have any reasonable number of users you really would be better looking at none WiFi technology, especially over long distance.
Content for Community-Ad
August's Community Spotlight Awards
