ssid not displayed
Hi I have a problem with a WLC 5508 the problem is that in one AP I didn´t see one SSID but I could see the SSID for the
guest users.
In the clientes I saw the SSID and them I didn´t see it so the clients couldn´t connect to the wireless, this onle happen in this AP.
for the moment I don´t know if all the clients couldn´t see the SSID or only happen with a specific clients.
Thanks....
5 Replies 5
Azariel
What ID did you use for this WLAN? when you created you new WLAN the WLC ask for an ID, you must choose 1 to 16, if you choose any value > 16 the SSID is not broadcasted less you have some AP Groups
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
It´s the number 4.
so... you're saying you can see this WLAN in ther AP's? just one doesn't? O you can see it at all?
SSID is enable? Broadcast is enable?
Abhishek Abhishek
Hello Azariel,
As per your query i can suggest you the following solution-
Configuring Fast SSID Changing
When fast SSID changing is enabled, the controller allows clients to move between SSIDs. When the client sends a new association for a different SSID, the client entry in the controller connection table is cleared before the client is added to the new SSID. When fast SSID changing is disabled, the controller enforces a delay before clients are allowed to move to a new SSID.
Hope this will help you.
I test in one client and I saw the SSID but in the next 4 seconds I didn´t see that SSID but the strange is that I can see another SSID that is in the same AP.
The SSID is enable and broadcast in enable too.
Thanks...
